Activity › Forums › Apple Final Cut Pro Legacy › HDmpg in PAL Format
HDmpg in PAL Format
Posted by Suzin Daly on December 15, 2008 at 2:45 pmIs it possible to use MPEG Streamclip with a HDmpg in PAL format copy the DVD to bring into FCP?
Reason is I do a cable TV show airing independent films we coppy the movie short through Streamclip drop it on the time line for the show. This is a a 15 minute short
Stuart Simpson replied 17 years, 9 months ago 3 Members · 5 Replies -
Stuart Simpson
December 15, 2008 at 3:07 pm[suzin daly] “Is it possible to use MPEG Streamclip with a HDmpg in PAL format copy the DVD to bring into FCP?”
Sorry if I’m being dense here – but what are you trying to do exactly? You have a HD clip that you want to put into FCP? Why do you need a DVD?
-Simmie
5 MacPros – Kona 3 & Kona LH
2 G5s – Kona LH
xbox360, Wii, PSP, PS2
https://www.speak.co.uk -
Suzin Daly
December 15, 2008 at 7:12 pmYour not dense I’m not being clear enough.
I am being sent a DVD from Germany, below is what he wants to send.
Would you also accept a HDmpg in PAL format?
I need to drop the movie into a timeline for a TV Show, NTSC.When filmakers send me their DVD’s I usually use MPEG streamclip to get a copy to drop into the time line. I don’t get sent
data disks that I can drag off. Everything I get is NTSC.What I am trying to figure out is how to get DVD HDmpeg PAL (needs to be turned into NTSC I assume) for FCP for the show. I need to somehow copy a PAL into an NTSC format to bring into FCP time line.
I think the bottom line is, how to get PAL format into the time line for FCP.
How to convert PAL into a MOV. That is the question
Arnie Schlissel
December 15, 2008 at 9:58 pmIf he sends you a video DVD, it will no longer be HD. I’m often amazed at how many “filmmakers” don’t understand this.
If he sends you a DVD-ROM, then he can use whatever format he wants at whatever resolution he wants, so long as he can get it to fit on the DVD.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Suzin Daly
December 15, 2008 at 10:07 pmHe is not the editor. He asked the question about sending HDmpeg PAL because that is all he has at this time. I was just putting it out there to see if there was a way to go from PAL to NTSC without a lot of drama. This TV Station is not putting out HD so that is mute.
Stuart Simpson
December 16, 2008 at 10:55 amI think this might be one of these cases where you just see what he sends you… If you do get a HD clip in m2v format on a data DVD then you should be able to use MPEG Streamclip to convert it.
-Simmie
2 G5s – Kona LH
