Activity › Forums › Blackmagic Design › HDMI deck control with an intensity card?
Posted by Paul Nevison on September 13, 2007 at 3:46 amwhen capturing from an HDMI enabled deck via an intensity card do you have full deck control?
thanks
Geoff Addis replied 19 years ago 5 Members · 16 Replies -
Igor Babic
September 13, 2007 at 9:06 amYou can’t control deck thru HDMI. You are controling your deck with Intesity only thru FireWire. In your capture application you have to use apropriate BMD setup and choose DV/HDV device for control (before capture you have to connect both cables HDMI and FireWire!) or make your own one.
Igor Babic
September 13, 2007 at 12:37 pmLast week I have captured 20 hours of HDV tapes that way. I have also enable downconwert on input because my final is SD, and I have captured all in MJPEG. It works, and real time downconvert is very good.
Justin Ferar
September 13, 2007 at 11:29 pmYou can also use the RS422 on the HD50 for full deck control.
Geoff Addis
September 14, 2007 at 7:07 amIs there any way in which footage can be split into individual clips at timecode breaks when capturing via HDMI/Component input to the Intensity Pro with Firewire deck control?
Geoff
Igor Babic
September 14, 2007 at 5:24 pmIntensity has no RS422 control. You have to use some external one.
Igor Babic
September 14, 2007 at 5:32 pmI have not use it this way, but once I forgot to watch my ingest it didn’t stop at the end of recording, and also never stops on TC breaks on some other tapes. Intensity has also some special app for ingesting but I have not use it. All my capture was done with PPro2.
Justin Ferar
September 14, 2007 at 6:49 pmYou can use your USB connection with this…
https://www.decklink.com/support/detail.asp?techID=178
It works perfectly- I use it everyday.
Geoff Addis
September 15, 2007 at 6:41 amDoes the Keyspan Serial Adaptor approach allow scene detection and auto clip split functtionality?
Geoff
