Activity Forums Blackmagic Design HDLink with Quantel Paintbox?
  • HDLink with Quantel Paintbox?
    Posted by Jimmy Brunger on November 22, 2007 at 12:30 pm
    I’m trying to find a way of monitoring our old Paintbox Express on a Dell 2047FP effectively – we rarely use it, but need it for archived work occasionally and I’m not wasting a Sony BVM broadcast monitor on it for that!
    Looking at various solutions I wondered if HDLink would work well? It’s SD PAL coming out of the spare SDI o/p from the Paintbox, then DVI into the Dell..
    – I know you’re supposed to use a 1920×1200 display for PAL, because of 2x resizing, but surely 2 x 720×576 is 1440×1152? so should my 1600×1200 display work ok?
    – Also, the Paintbox is an RGB output, not YUV…is this supported/converted by HDLink? I know RGB 4:4:4 is with dual link, but this is not dual link.
    – The other thing is ‘lag time’. I’ve tried a cheapy component>VGA converter from Maplin and despite the bad pic quality and no support of RGB it seems to lag behind what you’re doing with the cursor..I presume this is a latency with the cheap converter, because my Dell is plenty responsive with Photoshop, etc on my PC? Does HDLink have any Latency issues?
    – Does HDLink have a 16:9 switch anywhere so it displays correctly on my 4:3 display?
    – Are there any other decent SDI/Component > DVI/VGA converters on the market that might suit me better for SD work rather than HDLink? I’ve seen a couple from cyp.co.uk, but I don’t think they adjust for PAL pixel shape and looks like their RGB input is a scart which is no good..
    Thanks for any advice anyone has.
    Jim.
    *Production Studio Premium CS2 / *Combustion 3 / Mocha v1
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0
    Jimmy Brunger replied 18 years, 9 months ago 1 Member · 1 Reply
  • Jimmy Brunger
    November 22, 2007 at 12:58 pm
    Anyone in the know what’d be best for my situation?:
    https://www.lektropacks.com/view_product_standard.php?product=104&department=2&sub1=17&show=56
    Only thing with this is that looks like the only way to RGB into it is via a scart (presuably with somesort of dodgy phono component>scart converter bolted on aswell…and not sure if this only outputs square pixels?
    HELP!
