Activity Forums Blackmagic Design HDLink Pro separate LUT’s for SDI/DVI
  • HDLink Pro separate LUT’s for SDI/DVI
    Posted by Toby Tomkins on August 22, 2011 at 4:50 pm
    Hi all,
    Quick question (hopefully). Can you have separate LUTs applied to the SDI-out and the DVI(HDMI)-out?
    I want to know as I want to run a grade 1 monitor off HD-SDI and projector off HDMI (DVI), both needing different LUT’s for accurate monitoring.
    Also, is it worth getting the display-port model or will the DVI (with HDMI convertor) output 10 bit (or will only the display-port)
    Toby
    Kristian Lam replied 15 years ago 2 Members · 1 Reply
  • Kristian Lam
    August 22, 2011 at 5:07 pm
    [Toby Tomkins] “Quick question (hopefully). Can you have separate LUTs applied to the SDI-out and the DVI(HDMI)-out?
    You can only run 1 LUT and they apply to both the SDI out and the DVI/HDMI output.
    [Toby Tomkins] “Also, is it worth getting the display-port model or will the DVI (with HDMI convertor) output 10 bit (or will only the display-port)
    The DisplayPort version will support 10-bit HDMI but the DVI version is 8-bit HDMI/DVI.
    regards
    Kristian Lam
    Blackmagic Design
