HDlink PRO –> Eizo CG242w — 50hz ?
hello,
does anybody from europe has the same setup?
HDSDI (1080i50 or p25 or pal) –> HDlink PRO –> Eizo CG242w
no 50 hz in monitor is detected, so motions are shuttering…
720p50 is detected with 50 hz.
EDID override in HDlink PRO not possible because of the hardware of the HDlink pro…
So it is not possible to view 50hz formats correctly with this setup?
Maybe somebody can inform me about this issue…thanks
christoph
