Activity › Forums › Blackmagic Design › HDLink Pro DisplayPort
  • HDLink Pro DisplayPort
    Posted by Neil Sadwelkar on February 11, 2012 at 4:03 am
    I tried searching but could not find a precise answer of recent enough date.
    Does the BM HDLink Pro DisplayPort work with the Apple Cinema 27″?
    What kind of a DisplayPort to mini female DisplayPort adapter is needed?
    Will this arrangement output 1080p HD as scaled to 2560×1600, or 1:1 ‘windowed’?
    Will this arrangement output 2k via a BM Extreme HD3D card over 3G HDSDI?
    Is anyone actually using this as a monitor?
    Is there a list of monitors qualified for use with the BM HDLink Pro DisplayPort?
    Finally, will the new 27″ Thunderbolt Cinema Displays work with the HDLink Pro DisplayPort?
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
    Arun Kumar replied 13 years, 11 months ago 2 Members · 1 Reply
  • Arun Kumar
    October 26, 2012 at 1:30 pm
    Hi Niel,
    I am using same setup as you mentioned above.
    1. Apple Mac Pro –
    2. Decklink HD Extreme
    3. Resolve 8.2
    4. HD Link Pro ( Display Port )
    Did you happen to find a way to VIew 2k output on Apple Display ..??
    Connection :
    BM Decklink Extreme –> SDI –> HD Link Pro –> Displayport –> Displayport to Mini Display Port –> Apple 27″ Cinema Display
