Activity Forums Blackmagic Design HDLink – is the HDMI 10bit
  • HDLink – is the HDMI 10bit
    Posted by Rory Hinds on July 22, 2010 at 6:02 am
    Could someone from Blackmagic confirm what the spec of the HDMI is on the HDLink product range.
    Is it HDMI 1.4?
    Does it output in 10bit?
    Is it switchable between RGB & YUV?
    Seems the mini convertor is 10bit and switchable between RGB & YUV but you can’t load a 3D LUT into it so I’m hoping the HDLink will deliver.
    Rory Hinds
    mine
    http://www.minefilms.com
    Rory Hinds replied 16 years, 2 months ago 2 Members · 2 Replies
  • Neil Sadwelkar
    July 24, 2010 at 8:54 am
    From the Blackmagic HD Link Pro 3D page…
    HDLink Pro 3D DisplayPort also supports HDMI 1.4 for compatibility with the latest full resolution 3D televisions!
    SMPTE 352M video payload identification ancillary data is used for automatic input format recognition and RGB/YUV color space detection. Color precision is at an incredible 10 bit in both SD and HD formats. Video data is automatically rounded down to the bit depth of the connected LCD display for superior viewing quality.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Rory Hinds
    July 24, 2010 at 3:23 pm
    Hi Neil
    I was told by BM that is only does RGB out and its not selectable between RGB and YUV like the mini convertors.
    Rory Hinds
    mine
