Activity Forums Blackmagic Design HDLink & 30″ Apple Cinema Display HD
  • HDLink & 30″ Apple Cinema Display HD
    Posted by Robin on June 11, 2006 at 7:42 am
    Considering to purchase both the above products. All the information that I saw about the HDLink for HD monitoring relates to the 23″ display. Has anyone used this product on the 30″? Does the entire screen gets used or does the footage only appear on the screen in it’s native resolution and the surrounding area being black? Please advise.
    -Robin
    Kristian Lam replied 20 years, 2 months ago 4 Members · 6 Replies
  • Sean Lander
    June 11, 2006 at 7:56 am
    Doesn’t work with the 30″. I think you need the Multibridge Extreme for that.
  • Kristian Lam
    June 11, 2006 at 8:09 am
    The connectors on the HDLink is a single link DVI-D. The 30″ Cinema Display requires a dual link DVI-D display so they are not compatible.
    regards
    Kristian Lam
    Blackmagic Design
  • Robin
    June 12, 2006 at 5:08 am
    Kristian,
    Tx for the info (and prompt reply). Sean mentioned that the Multibridge Extreme supports 30″. Does the image of the video (both SD & HD) gets scaled to the full size of the monitor? Please advise.
    Cheers,
    -Robin
  • Sergio Deustua
    June 13, 2006 at 8:42 am
    Im using Multibridge and apple cinema display 30″. The result: a beautiful full sreen image. This is with HD, don
  • Robin
    June 13, 2006 at 11:28 am
    Tx. Time to place an order. Hehehe.
  • Kristian Lam
    June 14, 2006 at 6:24 am
    Hi Robin,
    When displaying SD video, the Multibridge Extreme will scale to the full height of the 30″ display. However, you will get black bars on the side of the screen as the aspect ratios are different.
    regards
    Kristian Lam
    Blackmagic Design
