Activity › Forums › Panasonic Cameras › HDD/AJ-PCS060 Question
  • HDD/AJ-PCS060 Question
    Posted by Tim Scarpino on July 13, 2007 at 2:41 pm
    Greetings All,
    I’m curious if anyone knows how the HDD unit writes data to its drives.
    Does it simply allocate one drive per card, or does it “overlap” data from a card onto a couple of drives if one becomes full?
    Also, should I be able to “play” clips from the HDD using the P2 viewer on my PC?
    As is too often the case with me…I don’t know what I don’t know!
    Tim Scarpino
    Adam Smith replied 19 years, 2 months ago 2 Members · 1 Reply
  • Adam Smith
    July 13, 2007 at 7:46 pm
    From what I’ve read, the P2Store makes a partition equal to the size of the P2 card you insert.
    Insert a 4gb card, and it makes a 4gb partition and then moves the files over from the card. Insert a 16gb card and it makes a 16gb partition.
    It works this way regardless of how much data is actually on the card. An 8gb card with only 3gb data still uses up 8gb on the P2Store.
    Video Photographer / Avid Editor
    Maximus Media Inc.
