Activity › Forums › Apple Final Cut Pro Legacy › HDCAM won’t edit to tape
  • HDCAM won’t edit to tape
    Posted by John Barnard on December 11, 2007 at 10:15 pm
    The problem I’m having is that my HDW-D1800 seems to be incompatable with the BLACKMAGIC prores edit to tape window. I can crash record a prores movie to the deck but when I use the “edit to tape” I only record the soundtrack and blobby green digital mess where the picture is supposed to be!
    Blackmagic Multibridge
    Final Cut 6
    Mac Pro
    Model Identifier: MacPro1,1
    Processor Name: Dual-Core Intel Xeon
    Processor Speed: 3 GHz
    L2 Cache (per processor): 4 MB
    Memory: 3 GB
    Bus Speed: 1.33 GHz
    Jeremy Garchow replied 18 years, 9 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    December 11, 2007 at 10:21 pm
    You might want to post this on the BMD forum, but are you dragging your sequence from the browser to the ETT window?
  • Walter Biscardi
    December 11, 2007 at 10:25 pm
    [John Barnard] “I can crash record a prores movie to the deck but when I use the “edit to tape” I only record the soundtrack and blobby green digital mess where the picture is supposed to be!”
    We have a Decklink forum here on the COW, you might want to post there.
    Sounds like you have an output mismatch somewhere if you’re not seeing video. I’m assuming you see the correct video going to your monitor?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • John Barnard
    December 11, 2007 at 10:30 pm
    I have posted on the blackmagic forum as well, but seems to be a collision of a whole bunch of issues so I thought I’d post here too. Yes, I’m dragging from the browser to the ETT window.
    John
    Final Cut 6
    Mac Pro
    Memory: 3 GB
    Bus Speed: 1.33 GHz
  • John Barnard
    December 11, 2007 at 10:33 pm
    Yes, I think it is an output mismatch, but I’ve tried all the easy setups that should work here. Seems strange that there’s no compatible output.
    And it did work with a crash edit, so how come not in the ETT window?
    The movie plays out fine via my monitor though.
    Final Cut 6
    Mac Pro
    Memory: 3 GB
    Bus Speed: 1.33 GHz
  • Walter Biscardi
    December 11, 2007 at 10:45 pm
    [John Barnard] “And it did work with a crash edit, so how come not in the ETT window?”
    Honestly don’t have an answer. We don’t run BlackMagic products here.
    Read my Blog!
  • Jeremy Garchow
    December 11, 2007 at 11:08 pm
    The output should be set to 10bit at whatever resolution you are working in.
    Jeremy
  • John Barnard
    December 11, 2007 at 11:41 pm
    Wouldn’t you know it.. I had the wrong reference video selected on the deck. Here’s what a friendly stranger told me:
    The trick is to make sure the reference is selected to ‘input’ NOT REFERENCE; otherwise you will get exactly what you are getting.
    And it worked!
    Final Cut 6
    Mac Pro
    Memory: 3 GB
    Bus Speed: 1.33 GHz
  • Jeremy Garchow
    December 12, 2007 at 12:02 am
    Got ya. That makes sense.
    Jeremy
