Activity Forums Apple Final Cut Pro Legacy HDCAM SR vs ProRes 4444
  • HDCAM SR vs ProRes 4444
    Posted by Russell Lasson on July 25, 2009 at 3:57 pm
    [Erik Lindahl] “Regarding ProRes vs HDCAM SR – If I’m not misstaken, HDCAM SR is 440 or 880 Mbit 10-bit where ProRes 4444 is 330 mbit 12-bit. Given ProRes is a new:er codec I guess it could beat HDCAM but you’re at a higher bit-depth and much lower bitrate. “
    DATA RATE/COMPRESSION @ 60i 4:4:4
    HDCAM SR 440Mb/sec or 4.2:1 compression
    ProRes 4444 330Mb/sec or 5.6:1 compression
    NOTE: While HDCAM SR is 10-bit and ProRes 4444 is 12-bit, ProRes compression ratios are most likely somewhat incorrect. But since there isn’t a common uncompressed 12-bit codec, I’m not sure how to me more accruate.
    Bit Depth
    HDCAM SR 10-bit
    ProRes 4444 12-bit
    NOTE: HDCAM SR supports LOG which, if used, essentially increases the bit depth to somewhere between 12 to 16-bits in the LIN equivalent.
    FRAME SIZE
    HDCAM SR 1920×1080 or 1280×720
    ProRes 4444 Any frame size. Real-Time 2K playback supported in Final Cut Pro.
    COST
    HDCAM SR $100,000 Plus
    ProRes 4444 $1000+Hardware
    Now I know that this comparison is kind of silly on some levels. HDCAM SR is an industry standard delivery format. ProRes is an editing codec.
    If talking about FX/Color work, then HDCAM SR has less compression. ProRes 4444, though more compressed, has 12-bit colors, variable frame sizes (SD through 2K+), supports alpha channels, very manageable data rates, and is a much less expensive workflow.
    For broadcast distribution, HDCAM SR is great. Otherwise, if you’ve finished to ProRes 4444, you’d be better off archiving/mastering at a QT file backed up to LTO or a drive.
    I’d love to hear peoples opinions on this, especially if I have any facts wrong! Gary, maybe you can add some more to the conversation.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
    Chris Filiano replied 16 years, 10 months ago 9 Members · 27 Replies
  • 27 Replies
  • Erik Lindahl
    July 25, 2009 at 4:15 pm
    It would be interesting to compare ProRes 4444 as both a TRANSPORT codec and a PRODUCTION codec. If it compares well to HDCAM SR as a transport codec that would be awesome. My fear it will not hold up to uncompressed formats in production. It has to width-stand 2-3 generation and still hold for perfect keying and color correction. The 12-bit of the format speaks in it favour but it’s still a compressed format that will deteriorate between generations.
    So, in the future, my question really is when working with film can we go:
    Film > Telecine > ProRes > Output
    And hold the same or better quality than the established standard we use today
    Film > Telecine > HDCAMSR > Uncompressed > Output
    If the first workflow DOESN’T hold it would be interesting to see if / how just using ProRes as the transport codec would, i.e:
    Film > Telecine > ProRes > Uncompressed > Output
    The few projects I’ve done with ProRes before have been riddled with compression artifacts. This can of course be due to the original recording media (AVCIntra on one project was pure hell to color correct and key).
    Erik Lindahl
    Freecloud Communication
  • Russell Lasson
    July 25, 2009 at 4:33 pm
    [Erik Lindahl] “Film > Telecine > ProRes > Output
    And hold the same or better quality than the established standard we use today “
    Hopefully it is as good as a HDCAM SR DI workflow. But even if it isn’t, people are going to see that it can be a much less expensive option and they’re going to do it. Independents are just going to eat up ProRes 4444, especially those shooting on digital cinema cameras.
    Now if AJA can somehow manage ProRes 4444 support on the Ki Pro over a 3Gbps HDSDI signal, then watch out! That makes it a sub-$4k, 4:4:4 recording option that will play very, very nicely with an edit system that has 1.3+ million users. That could be a very impressive combination. Even if it isn’t “technically” as good as the current options.
    [Erik Lindahl] “The few projects I’ve done with ProRes before have been riddled with compression artifacts. This can of course be due to the original recording media (AVCIntra on one project was pure hell to color correct and key). “
    I’d suggest looking into Gary Adock’s article on ProRes:
    https://provideocoalition.com/index.php/apple/story/prores_a_closer_look/
    -Russ
    Russell Lasson
    Color Mill
    Salt Lake City, UT
  • Rafael Amador
    July 25, 2009 at 4:50 pm
    Here there is a lot of useful info about the new Prores:
    https://images.apple.com/finalcutstudio/docs/Apple_ProRes_White_Paper_July_2009.pdf
    Cheers,
    rafael
    http://www.nagavideo.com
  • Hector Berrebi
    July 25, 2009 at 8:26 pm
    hi Russell
    this from the new ProRes white paper:
    doesn’t it suggest ProRes 4444 is 6.7:1?
    also, HDCAM SR has an HQ mode with 880 Mbs and 2:1 compression ratio
    which ProRes is quite far from…
    i don’t think ProRes is meant to compete with SR…
    but having it available for cheep, from SD to 28k in 4:4:4 and 12 bit color depth with support for alpha channel , in RGB or YCbCr color space is so cool and probably so useful
    is there a better work format on the market?
    this so much kicks DNxHD in the ass… it used to have in its favor over Prores, the fact that it supports alpha channel and offline sizes.
    now it only has the fact its free 🙂
    new ProRes definitely means DNX needs a brush-up
    lets hope AjA are working on a new input for the Ki-Pro…
    Hector Berrebi
    Schibber Group
    prePost Consulting
  • Erik Lindahl
    July 25, 2009 at 8:50 pm
    Post-houses might embrace this format given it proves to be on-par with HDCAM SR it might serve very well as a transport codec. My concerns remain if it’s good enough for a finishing codec or not.
    What ever the case there is still going to be a cost and time-gap before it really takes any serious leap. If a device like the AJA KI where to embrace the 4:4:4 ProRes codec things could perhaps change, quite rapid…
    Looking at the real high-end, the two major telecine-facilities here in Stockholm either go from film to dpx files, then grade or go from film and directly grade to HDCAM SR. If we today require QuickTime files these always come from the HDCAM SR source. A film to ProRes transfer might be simlar to HDCAM SR but the end user where to get a Film > HDCAM SR > ProRes > ??? transfer you have passed through two different compressed codecs.
    So yeah, the question remains – good enough for transport and / or production.
    Looking at working with digital formats such as RED again I’m not sure either. Given this is an extremely compressed format finishing in another compressed format feels so-so. Visually lossless isn’t a lossless format, after 2-3 generation ugly issues can show them selves on post-heavy shots (given then you perhaps should avoid RED in the first place).
    Erik Lindahl
  • Erik Lindahl
    July 25, 2009 at 8:57 pm
    I believe I stated the same thing in another thread. I’ve even had discussions with post houses regarding going HDCAM SR 4:2:2 or 4:4:4 and they’ve suggested 4:2:2 since it has less compression artifacts given lower color resolution.
    I still hold a level of “uncertainty” regarding the whole use of ProRes for high-end finishing, given it very much has hits home for a lot of post-production. I could have loved to see a lossless 4:2:2:4 and 4:4:4:4 codec with similar aspects as ProRes (but of course with larger filesizes).
    Erik Lindahl
  • Arnie Schlissel
    July 25, 2009 at 9:55 pm
    [Erik Lindahl] “Post-houses might embrace this format given it proves to be on-par with HDCAM SR it might serve very well as a transport codec”
    Not to be cynical, but post houses will embrace whichever format makes the most sense to them economically and logistically. If they can charge a client a few dollars more to use one format over another, they will offer it. If they can save a few dollars or a few minutes by using a specific format, they will.
    Post houses that adopted D5 before HDCam SR was available continue to sing its praises over SR. The shops that waited and bought the SR decks poo-poo D5 in favor of SR.
    Those shops that adopted DPX will trash talk TIFF. Those that standardized on TIFF will sing it’s praises over all other formats.
    The same will hold true with all flavors of ProRes. For shops that have an FC centric workflow, ProRes 4444 will be the hottest thing since sliced bread. Shops that are Avid or Autodesk centric will reluctantly agree to accept it.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Russell Lasson
    July 25, 2009 at 10:06 pm
    [Hector berrebi] “doesn’t it suggest ProRes 4444 is 6.7:1? “
    Excellent find! I couldn’t find a data rate for 12-bit uncompressed, but there it is.
    So correction, ProRes 4:4:4 is 6.7:1 compression.
    -Russ
    Russell Lasson
    Color Mill
    Salt Lake City, UT
  • Russell Lasson
    July 25, 2009 at 10:26 pm
    I don’t know what you’re talking about. I’m a FCP house… and everyone else stinks!
    -Russ
    Russell Lasson
    Color Mill
    Salt Lake City, UT
  • Mark Raudonis
    July 25, 2009 at 11:57 pm
    It is the networks or studios who dictate a delivery format, not the post houses. So all of this debate is MOOT! Pro Res may be a fine format for internal workflow, but if it has to go out the door as a deliverable, the studios are going to demand a tape (for archival reasons). Last time I checked, no tape format I know saves to Prores (except LTO as data).
    So, don’t throw away your HDCAMsr decks yet. You’re still going to need them for a good long time.
    mark
Page 1 of 3
