Activity › Forums › Blackmagic Design › HDCAM-SR Not supported by Decklink HD
  • HDCAM-SR Not supported by Decklink HD
    Posted by Jose Miguel on January 9, 2006 at 3:57 pm
    Hi!, I’ve a SRW-5500 in 720 50p configuration and I don’t know what the problem but I can’t capture from the deck, because only 720p 24,30 is supported for the varicam. But with HDCAM-SR I only can work in 720 at 50p or 60p. conclusion I can’t work with BD drivers…
    Luke what i need to do for editing at 720 50p?, It’s very important for me, it’s a big project.
    Thanks!!
    Jose Miguel Lome
    Kristian Lam replied 20 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
  • Juan Salvo
    January 9, 2006 at 4:03 pm
    As a work-around… you could set the Frame Convertor on the SRW to 1080-50i and then work in 1080 instead of 720p.
  • Jose Miguel
    January 9, 2006 at 5:07 pm
    I’ve all the material at 720 50p, and I can’t capture at this frame rate!. And my HDCAM-SR doesn’t have the converter option installed for converting to 1080i, and I don’t want this because I need progressive footage for key and slow motions
    I don’t understand the problem for capture 50p, I thinks the problems is only the driver.
    Thanks for your reply!, but I can work only at 720 50p
    Jose Miguel Lome
  • Kaspar Kallas
    January 9, 2006 at 5:44 pm
    You should be able to work in 60p at least there is a control preset for that
    -Kaspar
  • Jose Miguel
    January 9, 2006 at 6:00 pm
    I update the drivers and i can work at 60p, but I need 50p because all the footage was captured at 50p, and I’m from a pal country. And the transfer from 50->60 is no so good. Why 60p and no 50p? I think that is a disvantage for the europeans, or is a hardware problem?
    Jose Miguel Lome
  • Gunleik Groven
    January 9, 2006 at 9:49 pm
    Are you working in Final Cut?
    I think it doesn’t support 50p. (I was told, and hate it too).
    From the apple pages this comes up:
    HD at 1080i 50/60, 1080p 23.98/24, and 720p 23.98/30/60
    No 50p…
    https://www.apple.com/finalcutstudio/finalcutpro/specs.html
    Gunleik
  • Kristian Lam
    January 9, 2006 at 11:03 pm
    We do not support 720p50 as yet. Also, Final Cut Pro does not as well.
    regards
    Kristian
    Blackmagic Design
  • Jose Miguel
    January 10, 2006 at 10:36 am
    Thanks for your response!, can I work with premiere?
  • Gunleik Groven
    January 10, 2006 at 8:19 pm
    [Jose Miguel] “Thanks for your response!, can I work with premiere?”
    Kristian says BM doeb’t support 50p..
    This is going to be an issue in PAL-land.
    Gunleik
  • Kristian Lam
    January 11, 2006 at 2:48 am
    Fret not. This is something we’re looking into.
    regards
    Kristian
    Blackmagic Design
