HDCAM footage is incomplete in FCP
Hi, I am hoping someone might be able to help, I have captured some HDCAM 1080 50i footage through FCP with the Sequence Setting Apple Pro Res 422 1920 x 1080 (HQ) setting, via a Blackmagic card, the Capture Preset is Blackmagic HDTV 1080i – Apple ProRes (HQ).
Now a really strange thing is happening, the mov files look fine when you watch the raw footage in QT, but when you open the clip in FCP it’s black after about a third of the time – and this happens regardless of how long the clip actually is. So a 48 minute clip is showing up all black from about the 31 minute mark, and a 3 minute clip is black from about 2 minutes. I’ve tried deleting and re-importing the clip, also restarting and no luck.
I’ve also tried setting the project up in different ways but the clips just look the same – am i using the wrong capture setting? We can’t capture in full HD.
I’m using Final Cut Pro 6.06.
If anyone has any ideas that would be great!
Olive
