Activity › Forums › AJA Video Systems › HDCAM Deck and Aja Kona 3 card
  • HDCAM Deck and Aja Kona 3 card
    Posted by Ken Niblock on August 22, 2006 at 5:49 am
    Hello,
    Looking for some advise on a Kona 3 card in FCP5. Everything seems to be working as it should with the exception of getting audio in on the card. I am bringing the video signal in on SDI – which should bring the audio in too, but was not the case. I hooked up AES and was able to get audio signal to the card – played through the speakers. But no signal to FCP5. I have tried several different configurations – FCP settings – with no luck. Has anyone run into this problem or have any insight into how to make it work?
    Any help would be much appreciated.
    K
    The Lobby replied 20 years, 1 month ago 3 Members · 2 Replies
  • Christopher Tay
    August 22, 2006 at 9:38 am
    Go to the Kona Control Panel and check that the Audio Input is not set the AES/EBU..which is most likely to be. Change it to SDI Embedded and you’ll be sailing along.
    -chrispy
  • The Lobby
    August 23, 2006 at 2:11 am
    +1 for checking the Kona Control panel, also double check that you have selected to capture audio in the capture tool. sometimes we forget the simplest things!
