Activity Forums AJA Video Systems HDCAM CHROMA LEVELS “Through the Roof!”
  • HDCAM CHROMA LEVELS “Through the Roof!”
    Posted by Johnnie Travis on November 20, 2008 at 8:17 pm
    I am trying to convert some HDCAM footage to SD (NTSC Betacam SP). I’ve tried bringing in both 1080i and 525i through the KONA LHe. When I drop the 1080i footage into an HD sequence, the chroma levels in the vectorscope look fine. When I drop the HD, or, down-converted HD (the 525i) footage into the timeline, the chroma levels are through the roof. I tried correcting the chroma with the CC 3-WAY, RGB limiter, and Broadcast safe filters to no avail. This issue comes up no matter what sequence setting I try (HD, or SD). I’ve also tried using both 10-bit uncompressed and ProRes 422 HQ. Does anybody have an idea how I can correct this? I need to lay this footage to Betacam SP.
    FCP 6.0.4
    KONA LHe 6.0.1
    HDCAM – SONY JH3
    Johnnie Travis
    Bob Zelin replied 17 years, 9 months ago 2 Members · 1 Reply
  • Bob Zelin
    November 20, 2008 at 11:41 pm
    I have never seen this problem. Do you still have the HDCam VTR ?
    Most HDCam VTR’s have analog outputs on them, and will let you patch directly into a Beta VTR. Even the J-30 series has composite video output. You can try to patch the composite video out of a J-30 into a Beta composite video in- JUST TO SEE WHAT HAPPENS. If it doesn’t work – it ain’t the FCP system.
    THEN, you can close FCP, open up the Kona Control Panel, click on CONTROL/Input Passthrough, and try your test again just using the AJA control panel to downconvert the HD-SDI signal to Beta Component. If this works, but FCP does not – it ain’t the AJA !
    BobZelin
