Activity › Forums › AJA Video Systems › HDCam 29.97 to DV 29.97 — visual artifacts, field order issue?
Oliver Peters replied 21 years, 5 months ago 4 Members · 11 Replies
Oliver Peters
May 3, 2005 at 11:22 pmPierson,
You are right and I apologize if my response was a bit too flip. I reread the PDF for the Kona2 manual and the only sections that are applicable are around pages 50 and 70. To do what you wanted to do, does sort of assume that you know that by changing to 525i, a downconversion will occur on input. It is generally best to stay with the easy set-ups.
Sincerely,
OliverOliver Peters
Post-Production & Interactive Media
Orlando, FL
http://www.oliverpeters.com
