Activity Forums AJA Video Systems HDCAM 1080/30P compatibility with Kona
  • HDCAM 1080/30P compatibility with Kona
    Posted by Scott Shucher on September 29, 2006 at 1:15 am
    Has anyone had any success with HDCAM video shot with an F900 at 1080/30P, and working with it on a Kona 2?
    I have a client that shot at this format (without consulting the editor), now they want to post it. I understand it’s not a format that will downconvert cleanly to SD. I’m told by the client, that’s OK because it’s not for broadcast, and will always remain in the HD or non-interlaced realm. (Yea, right. How many times have we heard that).
    G5 2.5ghz DP, 2.5Gbyte RAM, FCP 5.0.2, OSX.4.1
    QT7.01, Kona2 w/Kbox, Atto UL3D, Medea RTRX640, Huge MV 1.8Tbyte, Radeon 9800XT
    Scott Shucher replied 19 years, 11 months ago 2 Members · 2 Replies
  • Walter Biscardi
    September 29, 2006 at 1:17 am
    [Scott Shucher] “I understand it’s not a format that will downconvert cleanly to SD. I’m told by the client, that’s OK because it’s not for broadcast, and will always remain in the HD or non-interlaced realm.”
    Not sure who told you that. Good Eats is shot in 30p HD on the Varicam and downconverts to SD perfectly for the standard broadcast of the show. If you’ve watched any of the last two seasons of the show, you’re watching 30p downconverted to SD.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Scott Shucher
    September 30, 2006 at 1:29 am
    Hello Walter,
    I got the above info from the Sony HDCAM FAQ website:
    “29.97PsF/30 PsF: If a program is being created in Progressive scan mode, where better temporal resolution is desired, these modes should be used. The 29.97P mode will allow a 480i SD output. The 30P mode will not.”
    Anyway, are you able to run it through your Kona 2? I’ve been getting conflicting reports as to whether it works. Aja tech support says it’s “not supported”, which doesn’t necessarily mean that it won’t work.
    Also, I would suspect that the Varicam’s 30P, is a different bowl of soup from HDCAM at 1080/30P.
    Scott
    G5 2.5ghz DP, 2.5Gbyte RAM, FCP 5.0.2, OSX.4.3
