Activity › Forums › Blackmagic Design › HDCAM 1080@25Psf no video input
Posted by Jordi J recort on July 13, 2007 at 6:57 pmHello to all…
I have a J-H3 connected to a Multibrigde Extreme…
My FCP Easy Setup it’s configured to 1080i50 as is explained on the BMD website and found here in several posts..but I have the “no video input” message on my Log&Capture window…
Remote it’s oka
SD downconverted output it’s working fine…
I have checked 3 cablesAny Idea?
thanks!
Jordi J. Recort
Composer & Editor
Andres Posada replied 19 years, 2 months ago 2 Members · 8 Replies -
Andres Posada
July 13, 2007 at 7:19 pmAnother confirmation that there is a problem with 6.2 drivers.
Andres Posada
July 13, 2007 at 7:36 pmJordi,el problema son los drivers version 6.2. No hay ningun problema con tus cables. Hay que presionarlos por la version 6.3 mandando emails a soporte de Blackmagic.
Jordi J recort
July 13, 2007 at 9:22 pmWell.. now it’s working…
I have connected the HD Analalog component out…
Swicthed the BMD Pref Pane to YRB input…
and, Voila! it’s working…then, just for curiosity I plugged back the SDI Cable to the HD-SDI input.. went again to the BMD Pref Pane and select SDI input…
and, can you imagine… now its working… I din’t changed anything else.. sable setup, same cables…
this seems very odd but now it’s working….
BTW; Andres.. Drivers 6.3 should be around the corner, because Decklink Drivers are already 6.3 and the Eclipse will be shipping at the end of July…
cheers!
Saludos! -
Jordi J recort
July 13, 2007 at 9:25 pmHola Andres,
Como comentaba en ingles para todo el mundo.., supongo que los 6.3 estan al caer, pero supongo que saldran con el nuevo Eclipse….
Lo curioso es que tengo otro multibrige, y como conversor me ocurria lo mismo…
ahora despues de pasar por analogico.,, todo funciona
misterios!
Andres Posada
July 14, 2007 at 3:16 pmAcabo de confirmar que si es un problema de drivers y no de hardware. Si puedo tener se
Jordi J recort
July 15, 2007 at 5:17 pmAndres,
(english translation below)Hay un par de cosas que no me cuadran…. una senyal composite.. no es diferente segun el deck sea DV o Betacam… puede ser de mejor o peor calidad, puede tener mejor referencia o no.. pero una vez la senyal es analogica, ya no importa si viene de DV o Betacam
Andres Posada
July 16, 2007 at 12:58 pmI thought I had been inputing through analog video, which I had connected, but the signal I was seeing in Deck Control was from firewire. So it is back to zero and I am sending my MB to Blackmagic USA.
Andres Posada
July 16, 2007 at 4:09 pmJordi, I am working on NTSC. Please confirm that you are inputing analog video to the Multibridge, because if you are, then my Multibridge is defective.
