HD work flow
I have no problem importing canon mxf files using prores422; however when setting up the sequence the clip doesnot play back on a LED 1080p 120 hz screen using the Black Magic Intensity Pro card and frame rate of 30. The clip plays nicely at 23.98 fps. I am using prores422 as the sequence compressor.
What should I do?
Morrie
