Activity Forums Apple Final Cut Pro Legacy HD video on SD monitor shows jagged edges
  • HD video on SD monitor shows jagged edges
    Posted by Pradip Patil on May 24, 2010 at 5:28 pm
    Hi
    I have HD sequence in DVCPRO HD format at 1280×1080 which needs to be delivered as digibeta.
    Toda we monitored it on a SD monitor using SDI out. The system has Blackmagic HD Extreme Card. The image on monitor showd very bad jaaged edges in some of the shots.
    I guess it has to be the field order issue.Will the output on digibeta have same quality?
    Pradip Patil replied 16 years, 3 months ago 1 Member · 1 Reply
  • Pradip Patil
    May 24, 2010 at 7:02 pm
    Some extra info
    The captured clips as well as the sequence has field dominance set to NONE.
