Activity Forums Adobe After Effects HD to SD
  • Posted by Laurie Turner on March 10, 2008 at 6:10 pm
    I have created this intro with After Effects with HD dimensions, 1920 x 1080. My boss now tells me he wants it to fit 720 x 480 player and he doesn’t want the black bars. I tried creating a new come with 720 x 480 dimension but my graphic looks a little pixelated. I could scale down each element but this will take forever since I have a lot going on. What would you do?
    I am using After Effects CS3
    Laurie Turner replied 18 years, 5 months ago 3 Members · 3 Replies
  • Darby Edelen
    March 10, 2008 at 7:00 pm
    Well, the problem is that you will either need to use letterboxing (“those black bars”), or lose the left and right edges of your HD composition. I would recommend the 2nd option although it may take some reworking if you had necessary elements at the left and right edges.
    Create a new NTSC DV 720×480 composition, drag your finished HD composition into this SD composition. Then with the HD comp selected in the SD comp, go to Layer > Transform > Fit To Comp Height.
    It should look pretty good since you’re reducing the resolution, but you can try enabling the “Collapse Transformations/Continuously Rasterize” switch on the HD comp inside the SD comp and see if you like the results more.
    The nice thing about this method is that you don’t lose your HD comp, so if your boss ever changes his mind (happens all the time) and wants an HD version, all you have to do is render the HD comp.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Richard Harrington
    March 14, 2008 at 3:47 am
    My resizer template
    https://www.rastervector.com/downloads/resizer.zip
    Simply Option Drag your HD comp onto the solid layer for each size you need
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Laurie Turner
    March 24, 2008 at 12:34 pm
    Hey great! Thank you
