Activity Forums Blackmagic Design HD to SD using two cards… maybe not?
  • HD to SD using two cards… maybe not?
    Posted by Chemix Ferreiro on June 7, 2011 at 11:46 am
    Hello there (double posting on Aja forum)
    I’m trying to downconvert from 1080i (HDV timeline) to SD using both Macs at the studio, sending SDI out from Kona2 KBox downconverted to BM Decklink extreme SDI in. Results are less than acceptable… low, low quality signal…
    Should I get a nice, clean SD signal from this workflow? Any clues?
    Chemix Ferreiro
    BUNKER studio
    Canary Islands
    bunkerstudio.es
    Chemix Ferreiro replied 15 years, 3 months ago 2 Members · 2 Replies
  • Chris Tompkins
    June 7, 2011 at 4:13 pm
    The Kona II card will Down convert for you on the fly.
    Lay it out to tape via SDI and bring back in.
    OR
    Use Compressor.
    Chris Tompkins
    Video Atlanta LLC
  • Chemix Ferreiro
    June 7, 2011 at 4:57 pm
    I was hoping to avoid the layout-digitise cycle by importing to the Decklink at the same time the Kona is outputting but, as I already stated, results are far from Ok.
    Will try your suggestion and we’ll see…
    I’ve tried the compressor route and didn’t like it either…
    Thanks again
    Chemix Ferreiro
    BUNKER studio
    Canary Islands
    bunkerstudio.es
