i think this should work, no matter what…
if you have an hd comp or footage, be it 720p24 or 1080p24, and drop either into a widescreen sd, 24 fps comp, hit fit to comp and then render with the render settings changed to use 29.97, with fields and a pulldown. you should then get a widescreen sd 29.97 interlaced ntsc broadcast standard render.
if you have an hd comp or footage that is 720p60, you should be able to drop that into a widescreen sd, 29.97 comp and render that either with fields (smoother) or without fields (a little choppier), but both should look good. if you have problems with fields with that method , try a 59.94 widescreen sd comp and set the render settings to render 29.97 fps with fields.
if you have 720i or 1080i (29.97) footage, if everything is interpretted correctly, you should be able to drop that into a widscreen sd 29.97 comp, fit to comp and render 29.97 with fields or without. if you do see problems with field render, again try a widescreen comp with 59.94 fps and use the render settings to render it as 29.97 with fields.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW
