Activity Forums Apple Final Cut Pro Legacy HD studio monitor for use w/ FCP
  • David Roth weiss
    September 8, 2005 at 12:46 am
    Keep in mind that both TVs require certain compromises. Of course everything will be a compromise until all TV signals are HD.
    The 32″ is a 4×3 TV, so SD will be full-screen, while HD will be letterboxed (top and bottom) occupying a relatively small part of the screen. So, that one favors SD viewing at the HD viewing.
    On the other hand, the 30″ is a 16×9 TV, so while HD will display full-screen, SD will be letterboxed (on the sides), occupying a relatively small part of that screen, unless you stretch the picture, which will of course distort it. That one favors 16×9 HD viewing at the expense of SD.
    Hope this helps…
    DRW
