Activity Forums Adobe After Effects HD SR workflow in AEcs3
  • HD SR workflow in AEcs3
    Posted by Andres Bocan on January 30, 2008 at 8:15 pm
    Hi:
    Let me tell you what will be my job. If anybody see that something is wrong please let me know it.
    I will recieve a tiff secuence from a film transfer to HD SR 4:4:4. I will import it to AE CS3 and I will make the special effects there.
    Then when the effects are done I will export again to Tiff secuence to be edited in the finished On LIne.
    Is that OK ?? Will I deliver the same resolution and color depth 4:4:4 ?
    The format will be 1920×1080 59i. My comp should be at that rate so I will have the fields and then I will render the same way.
    But I insist my main concernt is the 4:4:4. Will I deliver the footage properly ?
    Anybody knows how much space of disk drive I will need for one sec of that footage ?
    Thanks for your help..
    Andres Bocan replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
