Activity › Forums › Apple Final Cut Pro Legacy › HD Shooting
HD Shooting
Posted by Patrick Morrow on July 5, 2007 at 12:02 amI have a Sony FX1 and I was wondering if there is any benifit to shooting HD if I deliver in standard 16X9 format? Also what are my choices for delivery as I am editing in Apple.
Thanks!!!
Patrick MorrowShane Ross replied 19 years, 2 months ago 5 Members · 8 Replies -
13
July 5, 2007 at 1:30 amVideo shot in HDV look WONDERFUL when they are down-converted to SD for delivery.
The most common delivery is still SD DVD, and it is quite simple to down-convert to SD DVD using compressor.
Uli Plank
July 5, 2007 at 6:25 amI’d rather use MPEG Streamclip for downcoverting, it does a great job and is much faster.
Regards,
Uli
Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
Carey Harrison
July 5, 2007 at 11:21 amTwo big advantages to shooting HDV vs SD
1) You can downconvert to SD (as stated earlier) and get great quality
2) VERY IMPORTANT – you or your client may change your mind and want (now or in the future) this footage posted HD…..and you’ll have it.
Good Luck, CHhttps://www.nightglassimagecenter.com/
https://www.lightsandcameras.com/
Patrick Morrow
July 5, 2007 at 6:00 pmDo you down covert while going into FCP, or do you down convert after editing using compressor?
Thanks!!!
Patrick Morrow -
13
July 6, 2007 at 4:19 amI prefer to edit and master in HD then doen convert using compressor. that way if the client wants a HD DVD later or a HD video file I do nit have to reedit.
Patrick Morrow
July 7, 2007 at 2:31 pmDumb question but how do you deliver on HD format right now if a client wants it?
Thanks!!!
Patrick Morrow -
13
July 7, 2007 at 3:49 pmwell because I have yet to meet anybody has a HD DVD or Blue-Ray DVD player, I have not invested in ether of those methods.
What I currently will offer is a HD video file. I myself and several others I know have a AppleTV. The AppleTV supports 720p 24fpc So I can convert the file to those specs (the new compressor has a preset for this) And the video look great.
Shane Ross
July 7, 2007 at 3:54 pm[Patrick Morrow] “Dumb question but how do you deliver on HD format right now if a client wants it?”
#1…find out the format of HD that they want.
HDV and DVCPRO HD…if you shot and worked in those formats, then you can output via firewire back to those formats just fine. But if they want a higher end format like HDCAM, D5, HDCAM SR, then:
#2 – Get a high def capture card like the Kona Lh, Kona 3 or Decklink Extreme…then rent a deck, might have to get a tri-sync blakc burst…or;
#3 Take your project to a post facility that is FCP based and have them do the output for you.
Shane
Littlefrog Post
http://www.lfhd.net
