Activity Forums Apple Final Cut Pro HD setting to shoot sports to downconvert to SD Widescreen
  • HD setting to shoot sports to downconvert to SD Widescreen
    Posted by Jason Garfield on July 24, 2012 at 6:15 am
    I’m going to be shooting some footage of a juggling competition to be incorporated into a live telecast on ESPN3. These will be competition highlight segments so they don’t have to match the exact look of the live telecast which will use different and better cameras. I’ll be shooting with the Panasonic AG-HMC150 and was wondering what the best setting to use would be to then down convert to SD widescreen. My initial thought is either 1080 60i or 720 60p. I’ve read that interlaced video is best for fast action sports, which this is. But I also want to be able to produce good quality slow motion and I won’t always have the option to shoot in the slow motion setting.
    So considering this needs to down convert to SD Widescreen to be telecast online and through x-box 360 onto flatscreen tvs (most likely) what would be the best HD setting?
    Dave Brandt replied 14 years, 1 month ago 2 Members · 1 Reply
  • Dave Brandt
    July 24, 2012 at 1:10 pm
    Considering that the distribution is online it will most likely be a progressive format for delivery. If you are able to shoot at 60p you will get much better slo motion than interlaced as even at 30p you will have 50% speed with no quality loss. I would shoot 720p60 and edit in 30p, and then convert to desired format for output
    Hope that helps
    Dave
    https://www.solidmedia.ie
    Macbook Pro 17″ i7 2.2 8GB
    iMac i7 2.8 16GB
    FCP 7 FCPX Adobe CS 5.5
