Activity Forums Apple Final Cut Pro Legacy HD-SDI output on a macbook pro 17″
  • Shane Ross
    May 11, 2007 at 4:54 am
    [mfassett] “Actually if you re-read my post… I don’t think I wrote “HD dual link.””
    “I need HD-SDI output in order to drive my external HD monitor. Problem… the Matrox MXO, the obvious choice which I just received, doesn’t support any monitors that are dual link.”
    Ah…I think I read into the question WAY wrong. Which is why I initially asked if you meant you needed HD SDI to power an HD monitor. Gotcha. Yeah, I see this is quite a quandry.
    In that case, the I/O HD will be your only option.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mfassett
    May 11, 2007 at 4:55 am
    Sorry Jeremy, wasn’t meaning to disrespect you! It’s always good to get 2nd opinions, just in case there’s a creative solution you or I may not have thought of.
    Thanks again for your recommendation, that’s most likely what I will end up doing.
    https://www.mfassett.com
  • Mfassett
    May 11, 2007 at 4:56 am
    Thanks Shane… of course, it’s three times the money of the MXO, but life is hard. 🙂
  • Jeremy Garchow
    May 11, 2007 at 5:01 am
    [mfassett] “Sorry Jeremy, wasn’t meaning to disrespect you”
    none taken. SOme people will tell you that editing on a laptop is ludicrous. With the ioHd and the fast storage options that you can connect to a laptop these days, I say they are ludicrous.
    jeremy
  • Jeremy Garchow
    May 11, 2007 at 5:03 am
    [mfassett] “it’s three times the money of the MXO”
    It is a much more powerful machine than the MXO.
  • Mfassett
    May 11, 2007 at 5:06 am
    Yea, I get that, but all I really need now is HD-SDI output… I’m sure once I get it I’ll find use for all the other features.
  • Jeremy Garchow
    May 11, 2007 at 5:11 am
    If you don’t need input, then the MXO and a 23″ is what you need.
  • Jeremy Garchow
    May 11, 2007 at 5:14 am
    Also, the ioHd isn’t available until July. The MXO you can get right now.
    Jeremy
  • Mfassett
    May 11, 2007 at 5:16 am
    Thanks, but now that I’ve had a taste of 30″ I’m not going back. I don’t need the input, but if that’s my only HD-SDI out option running the 30″, so be it.
  • Shane Ross
    May 11, 2007 at 5:21 am
    Well, you can use the 30″ monitor as your monitor, until you need to output, then you can use the MXO and your HD monitor. Or get the 23″ ACD. Or wait until July and get the I/O. One of my mottos is buy what you need when you need it. If you need HD SDI out now, then use the MXO and trade the 30″ for a 23″.
    Shane
    Littlefrog Post
    http://www.lfhd.net
Page 2 of 4
