Activity › Forums › Apple Final Cut Pro Legacy › HD-SDI output on a macbook pro 17″
Posted by Mfassett on May 11, 2007 at 12:53 amHello…
I just received my Macbook pro 17″ and Apple 30″ cinema… what a great combination, it’s hard to believe a laptop can drive a nice big monitor like that!
Anyway… I need HD-SDI output in order to drive my external HD monitor. Problem… the Matrox MXO, the obvious choice which I just received, doesn’t support any monitors that are dual link. So… either the MXO goes, or the 30″.
I think I really like having the 30″!
So… what other options, if any, are out there for me?
I know about the IOHD… which is the same price as my laptop, but if that’s what it takes I’ll buy it. Is there anything else?
Oh, and I can’t use the card slot, as that is occupied by my eSATA RAID controller.
Any ideas y’all? Thanks in advance…
Listen to the new Particle Salad CD at https://www.particlesalad.com
Wayne replied 19 years, 4 months ago 10 Members · 32 Replies -
Jeremy Garchow
May 11, 2007 at 1:24 amThose are your two options. My advice? The IoHD as it has input as well as output. The MXO is output only.
Jeremy
Shane Ross
May 11, 2007 at 3:28 am[mfassett] “I need HD-SDI output in order to drive my external HD monitor. Problem… the Matrox MXO, the obvious choice which I just received, doesn’t support any monitors that are dual link.”
What? HD SDI Dual Link to drive the 30″ monitor? That doesn’t make sense to me. I thought you needed Dual Link DVI ports to support that monitor. Do you mean you need Dual Link HD SDI to power an HD CRT? I thought that dual link HD SDI was for outputting to HD Decks.
I thought the MXO was dual link…I’ll have to check.
Shane
Littlefrog Post
http://www.lfhd.net -
Jeremy Garchow
May 11, 2007 at 3:43 amHis DVI monitor is dual ink, the MXO does not support a dual link monitor connected to it (probably because it needs one of the single links to output video) so it can only push a single link monitor, not a dual link.
Make sense?
Shane Ross
May 11, 2007 at 3:49 amOK…but he said “HD SDI Dual Link.” that is what confused me. DVI dual link is what the monitor needs.
I’d like to see if the AJA I/O HD will work with this monitor the same way a MXO works with the 23″ ACD. Because Matrox built in the gamma shift needed to turn a Cinema Display into a color grading monitor, and it has tools to adjust chroma, hue, brightness and contrast….and a blue only option. Wonder if the i/o HD will have that. If not, I don’t see how it could be used to make the 30″ monitor a color grading monitor.
Shane
Littlefrog Post
Shane Ross
May 11, 2007 at 4:13 am[JeremyG] “I don’t think the ioHD has DVI out…”
Nope, is sure doesn’t:
https://www.aja.com/html/products_Io_IoHD.html
So there is no way that you can get a nice decent image to the 30″ monitor. The MXO only supports the 23″ model AFAIK…and the I/O HD doesn’t output DVI.
Shane
Littlefrog Post
Jeremy Garchow
May 11, 2007 at 4:20 amCorrect me if I’m wrong, but I think he is looking for a single link HD SDI to drive his HD monitor and a dual link DVI to drive his 30″ for extra computer monitor space. The MXO won’t push his 30″ dual link computer monitor so he either needs to trade down to a smaller computer monitor to use the MXO to push his HD SDI Hd monitor OR not use the MXO and use the ioHD to push the HD SDI monitor and then use his laptop to push to 30″ DVI monitor for more computer monitoring. I don’t think he’s trying to use the 30″ for Hd monitoring.
Jeremy
Ronin Vidster
May 11, 2007 at 4:36 amIf you have to take the 30″ back and keep the MXO, consider this instead:
https://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=bsd&cs=04&sku=222-7315
It has the resolution of an Apple 24″ (full HD+) but is closer to your 30″ in size. Doesn’t require dual-link. Something to think about…..
Mfassett
May 11, 2007 at 4:46 amActually if you re-read my post… I don’t think I wrote “HD dual link.”
I have an apple 30″ which works great via dual link DVI from my Macbook Pro 17″. No problem.
The Matrox MXO connects to the DVI output of the Macbook Pro and provides an HD-SDI output (which is what I need) among other things.
The Matrox MXO doesn’t support dual link DVI.. in other words, the Matrox MXO connects to the laptop’s DVI output and provides a DVI output for a monitor.. but the MXO’s DVI output is only single link, so it will only support up to 23″ monitors. Thus, either the 30″ goes or the MXO goes. Make sense yet?
So, thus.. what I need is an HD-SDI output to drive my HD video monitor. The MXO doesn’t work for me.
Whew.
So are there any other choices other than the ioHD? That’s the big question y’all!
Jeremy Garchow
May 11, 2007 at 4:52 am[mfassett] “That’s the big question y’all!”
Which brings up right back to my first response. No.
Either trade in your 30 for a 23 and use the MXO, or live with the 30 and get the ioHD.
My recommendation? ioHD.
