Activity Forums Blackmagic Design HD + SD Output on Multibridge Eclipse
  • HD + SD Output on Multibridge Eclipse
    Posted by Oli Trenouth on March 12, 2008 at 3:55 pm
    Hi everyone,
    This might be stupid question, but should the MB Eclipse be able to output HD (eg. via HDMI), and downconvert to SD (for all other outputs) *at the same time*?
    I’ve got the box to downconvert HD->SD with good results, but it also downconverts the HDMI output. This makes checking graphics and font-sizes in both HD and SD a pain.
    Should this be possible, or am I asking too much of the Eclipse?
    Regards,
    Oli.
    Oliver Trenouth
    Media Developer / Editor
    National Media Museum, UK
    Chris Borjis replied 18 years, 5 months ago 4 Members · 3 Replies
  • Kristian Lam
    March 13, 2008 at 10:34 am
    Hi Oli,
    The Multibridge Eclipse does not output HD and SD simultaneously.
    regards
    Kristian Lam
    Blackmagic Design
  • Rob Alexander
    March 13, 2008 at 11:58 pm
    Is the same true for multibridge pro?
  • Chris Borjis
    March 14, 2008 at 10:28 pm
    The multibridge Extreme does do this but only in hardware and only for 1080i. I still can’t get an explanation why or when it will work for 720P.
    Kristian could you please explain this?
    The multibridge pro is the same, just as hdmi
    instead of DVI is my understanding.
    component output and dvi-d = HD
    SDI Channel B output = SD
    I use it whenever I work on HD material with client supervision.
    They really like seeing both at the same time.
