Activity Forums Apple Final Cut Pro Legacy HD-SD Downconvert Question
  • HD-SD Downconvert Question
    Posted by Joseph Wilkins on May 23, 2007 at 3:58 pm
    Hello.
    I have some 720p footage I shot on my HVX200.
    I cut a sequence in FCP using a 740 24p sequence.
    Now I want to take that and make it an SD timeline, so I used my “Easy Setup” and created a DV NTSC sequence and copied and pasted it all into the new sequence, but the footage looks blocky… and the fields look odd.
    I am not familiar with these terms, but hopefully it makes sense.
    What can I do here?
    thanks
    Russell Lasson replied 19 years, 3 months ago 2 Members · 1 Reply
  • Russell Lasson
    May 23, 2007 at 4:22 pm
    I like to use Compressor to downconvert from HD. If I were you I’d down convert to DV50, 8-bit or 10-bit uncompressed, or ProRes if you have FCP6.
    Here are the settings I created in compressor:
    Description: Uncompressed 10-bit NTSC Video with audio pass-through
    File Extension: mov
    Audio: multi-track passthrough
    Video Encoder
    Format: QT
    Width: 720
    Height: 480
    Pixel aspect ratio: NTSC CCIR 601/DV
    Crop: None
    Frame rate: (100% of source)
    Frame Controls:
    Retiming: Nearest Frame
    Resize Filter: Linear Filter
    Deinterlace Filter: Line Averaging
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Codec Type: Uncompressed 10-bit 4:2:2
    Multi-pass: Off, frame reorder: Off
    Pixel depth: 24
    Spatial quality: 100
    Min. Spatial quality: 50
    Temporal quality: 0
    Min. temporal quality: 50
    -Russ
