Activity Forums Apple Final Cut Pro Legacy HD Renders_Random Choppy Playback
  • HD Renders_Random Choppy Playback
    Posted by Joey Burnham on June 30, 2008 at 8:49 pm
    FCP 6.0.3
    OSX 10.5.2
    Hi All,
    We are having a couple of issues here at work that maybe someone else is experiencing and can help out.
    Recently we updated two of our bays to HD and have two issues which we can’t figure out.
    1) When working in 1080p 23.98 / Uncompressed 10-Bit (AJA), any footage that is captured requires a render. FCP preferences are fine as well as timeline options, sequence settings, etc. EVERYTHING checks out. Now, we have 2 other HD bays and the only difference is that they are still on 10.4.11. Even footage that is captured on those systems require a render on the 10.5 computers.
    Now here’s where it gets tricky. Once they render the footage and let’s say make a self-contained uncompressed QT, we can bring that footage into a 10.4 bay and quess what? No render necessary. So FCP in 10.5 is rendering to CORRECT settings. Why have to render if your settings are already correct?
    2) Renders from AE in 1080p 23.98 are playing back very choppy in FCP. And we did a test frame by frame and the motion stops are totally random. (I’m no math whiz, but the “pattern” was something like 11-1-11-1111-11-1-111-1-1-1-11-11 or something. (where – represents a stop in motion) In QT the files play fine. It’s an FCP issue. (Fix is to render out a image sequence, but it’s only a workaround)
    Sorry for the long post but I can’t really convey what’s going on without yapping.
    Best,
    Joey B
    Gary Adcock replied 18 years, 2 months ago 4 Members · 12 Replies
  • 12 Replies
  • David Roth weiss
    June 30, 2008 at 9:00 pm
    [Joey Burnham] “When working in 1080p 23.98 / Uncompressed 10-Bit (AJA), any footage that is captured requires a render.”
    Joey,
    You can stop right there, all the rest is pretty much extraneous information. If your footage requires a render (a red line), odds are your settings are not right.
    What camera was used to shoot this material?
    Are you certain the video was shot at true 23.98 and not 24pA?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY â„¢
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Joey Burnham
    June 30, 2008 at 9:23 pm
    Thanks for the quick reply. I knew that I’d get pounced on for this 🙂
    [David Roth Weiss] “odds are your settings are not right.”
    You would think that, but we had our technician come in to address the problem and he verified that all settings are what they should be. I’ve been working for a few years now with HD in FCP and I swear to you, settings are as they should be.
    [David Roth Weiss] “What camera was used to shoot this material?”
    I have no idea. This is feature film footage that we get from the major studios. They telecine to D5.
    [David Roth Weiss] “Are you certain the video was shot at true 23.98 and not 24pA?”
    The telecine is for sure 23.98, otherwise the d5 deck’s frequency (23.98) would conflict with the tape.
    Put it this way. 2 rooms, same settings. One is running 10.4, the other 10.5.
    Room 1 captures footage and has to render.
    Room 2 doesn’t have to render Room 1’s footage.
    If Room 1 had bad (capture) settings, Room 2 would need to render. (doesn’t need to)
    If Room 1 had bad (sequence) settings, Room 2 would need to render as well, but as stated before a rendered QT at sequence settings from the bad room DOES NOT require a render from the rooms that are fine. It’s like it’s going through the motions of a render rendering to the settings it’s already at (and has the item properties to back it up)
    Joey B
  • David Roth weiss
    June 30, 2008 at 9:36 pm
    [Joey Burnham] “I knew that I’d get pounced on for this :-)”
    Ah, I’m sensitive, hence the reason I said, “odds are,” because I know there are the occasional exceptions to every rule.
    Do me a favor Joey. Open a brand new project. Change the Easy Setup to 10-bit uncompressed 23.98. Open a new sequence. Drop a clip of the 23.98 video on the timeline. Then, don’t touch anything, don’t pass go, don’t collect $200, just report back and tell me what happens.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Joey Burnham
    June 30, 2008 at 9:45 pm
    Thanks David.
    Big red line on top.
    If I lay the same footage on a sequence in my room (10.4) I don’t need to render. I’m in the same easy setup.
    Have you heard of anyone having similar problems?
    Oh, and one more thing. The rooms can ETT just fine to the D5, which is definitely set up at the 1080p 23.98 frequency. (post render of course)
    FCP is seeing that the source is not matching the sequence settings (it is) and then rendering to the correct settings (that it already has).
  • David Roth weiss
    June 30, 2008 at 10:01 pm
    I just conferred with my associate Warren Eig, who had a brilliant idea. He said to check your RT settings, which probably got reset when you upgraded/updated. Set to unlimited RT first and see what that does, then tweak from there to your own needs if that changes things for the better.
    If that doesn’t work, then I suggest you unistall yoru Kona drivers using the Kona unistall utility (in the Kona apps directory) and then reinstall the appropriate drivers.
    If that doesn’t work, then you might do the same with the drivers for your raid array.
    If that doesn’t work, I have no futher ideas.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Joey Burnham
    June 30, 2008 at 10:06 pm
    [David Roth Weiss] “Set to unlimited RT first and see what that does, then tweak from there”
    THANK YOU!!!
    Unlimited RT and Dynamic did the trick. Gosh we rarely ever tweak the RT menu so I’m glad you suggested it.
    Joey B
  • David Roth weiss
    June 30, 2008 at 10:23 pm
    Joey, thank Warren Eig, he came up with the idea…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Gary Adcock
    June 30, 2008 at 11:53 pm
    [Joey Burnham] ” When working in 1080p 23.98 / Uncompressed 10-Bit (AJA), any footage that is captured requires a render. “
    Thats because the format is PsF and you are using a P setting
    The 1080 HDCAM in camera recorded format is PsF
    “. Why have to render if your settings are already correct? “
    they are not -thats because the render is solving the P vs PsF issue.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Gary Adcock
    June 30, 2008 at 11:56 pm
    [David Roth Weiss] “I just conferred with my associate Warren Eig, who had a brilliant idea. He said to check your RT settings, which probably got reset when you upgraded/updated.”
    Sorry david
    there is NO RT extreme in 10 bit Uncompressed 1080.
    it is a P vs SF issue. the P settings were not in the tiger version of the driver….
    gary adcock
    Studio37
  • Joey Burnham
    July 1, 2008 at 12:09 am
    Hi Gary,
    Now you have me a bit confused. 1st off, no HDCam here. My source is D5 which was telecined from film. Besides that, I do have an RT menu in my timeline, so what exactly do you mean when you say that there is no RT extreme in 10 bit uncompressed 1080?
    Also, the RT solution worked.
    Are you saying that in Tiger FCP cannot figure out to dump the extra segmented frame and display as progressive without a render?
    Joey
