Activity Forums Adobe After Effects HD Quicktime footage not playing all the way crashing ae
  • HD Quicktime footage not playing all the way crashing ae
    Posted by Heather Crank on July 31, 2009 at 4:12 pm
    Hello Everyone,
    I’ve been sent some green screened footage as a quicktime. The file imports fine into AE, but When I drag the file into a composition and try to view it at a quarter resolution (it’s only 80 mb) I can see maybe 3 frames. Then the video stops and the little swirling rainbow ball of death appears and doesn’t go away. Forcing me to quit ae and restart.
    When I check the quicktime info box in I see under codes “animation, integer little Endian”. I am guessing this is the culprit. Anyone ever run into this an know how to fix the problem?
    Thanks!!!!
    Heather Crank replied 17 years, 1 month ago 29,571 Members · 1 Reply
  • Heather Crank
    July 31, 2009 at 5:35 pm
    Hi Dave,
    Yes, I am on a mac. The quicktime is 8 seconds, but only pays the first second and then freezes. I think you are correct, the file may be corrupted.
    Heather
