Activity › Forums › Avid Media Composer › HD Quicktime Export Time is so long
  • HD Quicktime Export Time is so long
    Posted by Amy Tobey on April 26, 2012 at 4:11 pm
    I’m currently exporting an HD sequence in Avid Media Composer 5.5 on a Mac. My sequence is 6 minutes but takes over an hour and half to export this HD quicktime. Is there anyway to speed up this process without losing quality? Thanks
    Stacy Lincoln replied 14 years, 5 months ago 2 Members · 1 Reply
  • Stacy Lincoln
    April 26, 2012 at 4:24 pm
    HD takes a long time…especially if you’re using the Animation preset. That’s HD. Forget the days of fast SD export. When you get your file to the desktop (which is what I do), you can open it and re-export this large beautiful file in Quicktime pro as an H264.
    (Go under File/export when you open the file)
    This will also take a while…but it will be significantly smaller.
    You can export H264 straight out of AVID as well. But, I don’t always find the quality as good.
    You an also export a reference file and squeeze this in a program like Sorenson. Reference files are fast. But sometimes Sorenson doesn’t like them in the squeezing process…especially long form.
    Hope this helps. Just remember, HD will take a much longer time to export. We charge our clients for the time.
