  • Posted by Travisl on August 23, 2007 at 3:49 pm
    i wanted to confirm, If you shoot in HD edit in FCP studio or whatever, will you footage come out in HD? For example, i render then i shoot it to youtube or myspace. it’s not in HD at that point is it? I was told you need a HD burner to keep it HD
    Jeremy Garchow replied 19 years ago 4 Members · 4 Replies
  • Delano Bryant
    August 23, 2007 at 4:29 pm
    why do people look at youtube and even consider the quality should birth from HD. More like 3/4 or perhaps M2(for those of you in the know) Shot in sd widescreen, firewire into fcp dv/dvcpro ntsc. then make take into compressor and upload on the web. there ya go. better then youtube deserves.
    Is that the color red you want to use?
  • Rory Brennan
    August 23, 2007 at 4:44 pm
    You’re kinda tricking yourself up here.
    If you export the clip HD then it will remain HD. If you export it SD then it will be SD.
    Having a HD-DVD burner will allow you to burn HD-DVD’s, and without this burner you won’t be able to make HD-DVD’s, but that doens’t mean you have no other HD options.
    You can layoff to HD tapes or export HD Quicktime movies which you can put on your own Websites or burn to DVD/CD as data.
    I don’t believe youtube or myspace would accept HD. If this is to be the only destination for your work then don’t bother Digitizing the footage as HD. Just do it as SD to save Hard Drive space and allow for optimal system performance.
  • Travisl
    August 23, 2007 at 6:36 pm
    Thanks for the help, i think the first guy took this post wrong. I was making sure that information that I had was correct.
  • Jeremy Garchow
    August 23, 2007 at 6:49 pm
    Yeah, don’t know what was up with that answer.
    Here’s hope for the future:
    https://forums.creativecow.net/readpost/105/858123
