Activity Forums VEGAS Pro HD PVR MP4 files are cropped to the top left corner in Sony Vegas
  • HD PVR MP4 files are cropped to the top left corner in Sony Vegas
    Posted by Joshua Porter on July 11, 2011 at 2:16 am
    I have a video I recorded straight from my TV/Xbox with an HD PVR. The resolution is 1280×720 and when I play that video in Window Media Player, it plays fine.
    https://img62.imageshack.us/img62/6451/afterdawn1.png
    When I play it in VLC, the video is severely cropped off and NONE of the settings Ive used can change the way its played. VLC thinks whatever you see on the screen is the actual video itself. Changing the aspect ratio, etc. does nothing but add bars to the top and bottom of the video, making the cropped video be in the aspect ratio you choose.
    https://img835.imageshack.us/img835/9672/afterdawn2.png
    The problem with this is that Sony Vegas Pro, the program I use to edit my video, sees my videos the same way VLC sees them, not the way WMP sees them. As a result, my videos come out to be severely cropped to the top left.
    But here’s the weird thing, after tinkering around with VLC, I found this geometry setting that lets me do this
    https://img543.imageshack.us/img543/2803/afterdawn3.png
    And that’s it. That bar on the left side isn’t interactive, and the crop rectangle isn’t manipulable. So VLC KNOWS the entire video file exists somehow, just won’t play it.
    I’ve been scouring the Internet for a fix, not an avoidance to the issue because I’ve spent hours editing the video already so “Record it in x format using y settings” won’t work. I’ve come across DOZENS of different forums where people have had the EXACT same issue as I, and so far there have been ZERO solutions, only people who suggest avoiding the problem which won’t help me because I’ve already edited the movie.
    Here’s what I’m seeing now
    https://img94.imageshack.us/img94/1029/afterdawn4.png
    Thank you.
    Denny Hallas replied 15 years ago 6 Members · 10 Replies
  • 10 Replies
  • John Rofrano
    July 11, 2011 at 11:53 am
    Right-click on one of the video events and select Properties | Media and tell us what Vegas thinks the attributes of the video are (i.e., width, height, video format, pixel aspect ratio, etc.). Do they match the real attributes that you know the video is? (they should)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Joshua Porter
    July 13, 2011 at 7:05 pm
    Thanks, Mr. Rofrano, I have corrected the issue. But now I have questions regarding convenience.
    Say I have a movie with about 100 split clips and I want to remove clip 30 and have all the rest slide down. Is there a fast way to do that other than holding Ctrl and selecting each one and sliding them down/using Select Events to end (because sometimes you don’t want to select every event to the end)?
    Now say I have a movie with about 100 split clips all with text added using the Insert Text Media. I want to change the shadowing/font/font color for all them at once. Is there a way other than the obvious way of doing them each separately manually, or is there a shortcut for this? God, I hope there is.
    Thank you.
  • John Rofrano
    July 14, 2011 at 11:07 am
    [Joshua Porter] “I have corrected the issue.”
    It would be helpful to others in the community if you can explain how you corrected the issue. This way other people having the issue can correct theirs.
    [Joshua Porter] “Say I have a movie with about 100 split clips and I want to remove clip 30 and have all the rest slide down. Is there a fast way to do that other than holding Ctrl and selecting each one and sliding them down/using Select Events to end (because sometimes you don’t want to select every event to the end)?”
    Turn on ripple editing. This will close any gaps when you remove events from the timeline and make room for any new events. Be sure to turn it off after the events ripple because it could have some nasty side-effects if left on all the time.
    [Joshua Porter] “Now say I have a movie with about 100 split clips all with text added using the Insert Text Media. I want to change the shadowing/font/font color for all them at once. Is there a way other than the obvious way of doing them each separately manually, or is there a shortcut for this?”
    You are out of luck. There is not way to change the attributes of multiple text events. That would be a nice feature. You might ant to request it here: Sony Product Suggestions
    ~jr
  • Matthew Minas
    July 22, 2011 at 1:54 pm
    Hey mate,
    I’ve got the exact same problem, just wondering if you could let me know how you fixed? Thanks
  • Denny Hallas
    July 22, 2011 at 4:32 pm
    John,
    How can I find-out what the “real” attributes are?
    Denny
  • John Rofrano
    July 22, 2011 at 5:33 pm
    [Denny Hallas] “How can I find-out what the “real” attributes are?”
    Use GSpot or MediaInfo. Both can tell you what the attributes of the video file are.
    ~jr
  • Denny Hallas
    July 22, 2011 at 5:52 pm
    John,
    Thank you so very much.
    Denny
  • Allan Kuta
    July 31, 2011 at 6:54 pm
    Please tell me how you corrected the issue with the “top left cropping”. i have the same issue with no clue on how to fix it. i have looked all over the internet with no help.
  • James Johnson
    August 22, 2011 at 3:20 pm
    how is it that you then change the attributes?
  • Denny Hallas
    August 23, 2011 at 3:56 pm
    I’ll tell you how I’m going to resolve this issue: by contacting the Wisconsin BBB and Department of Justice: Department of Trade and Consumer Protection!
