Activity Forums Blackmagic Design hd pro card no video input
  • hd pro card no video input
    Posted by Pseudo1234 on July 17, 2006 at 6:20 pm
    here is my setup I have dual 2 ghz g5 running 10.4.7 fcp 5.1.1 and decklink 5.6.2
    Problem
    I am going SDI out of sony J-H3 deck downcoverted from 1080p 23.98 to ntsc 10bit 29.97 the decklink card is showing no video input on capture. I have tested the signal by going from deck to hdlink and i see picture but when i connect to decklink hd pro card i get no video input.
    Kristian Lam replied 20 years, 1 month ago 2 Members · 1 Reply
  • Kristian Lam
    July 21, 2006 at 4:34 am
    Capturing using Final Cut Pro? Are you using the provided NTSC easy setups? For example, “Blackmagic NTSC – 10 bit” that’s located in Final Cut Pro > Easy setup?
    regards
    Kristian Lam
    Blackmagic Design
