Activity › Forums › Apple Final Cut Pro Legacy › HD Playback drops frame – HELP
  • Erik Lindahl
    April 26, 2006 at 8:55 am
    Also: We did do a commercial a moth ago in this format that workd fine. Now, not so fine
  • Erik Lindahl
    April 26, 2006 at 9:41 am
    This is really strange
  • Erik Lindahl
    April 26, 2006 at 9:57 am
    Interesting
  • Erik Lindahl
    April 26, 2006 at 10:10 am
    Okey
  • Steve Connor
    April 26, 2006 at 10:25 am
    [Erik Lindahl] “Can files end up on “bad” places on the RAID?”
    Yes!
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Erik Lindahl
    April 26, 2006 at 10:30 am
    Okey! How does one prevent or “fix” these issues?
    The files I’m working on now was captured on a seperate station and transfered via a fire-wire drive to this one.
  • David Roth weiss
    April 26, 2006 at 4:07 pm
    Erik,
    I’d run Disk Warrior on the raid and see what it finds. Its very possible that your large HD video file was written in two or more fragments and the raid simply could not make the move from one fragment to another quickly enough to display HD. Disk Warrior will optimize the files on the array and should prevent that from happening.
    DRW
