Activity › Forums › Apple Final Cut Pro Legacy › HD Output Question
HD Output Question
Posted by Patrick Morrow on June 14, 2009 at 7:47 pmHello, Once I finish editing my HD project, can I just put it into Encore and purchase a blue ray burner and wola its a Hd disc?
Thanks for your time.Dennis Radeke replied 17 years, 3 months ago 4 Members · 7 Replies -
Walter Biscardi
June 14, 2009 at 8:22 pm[Patrick Morrow] “Hello, Once I finish editing my HD project, can I just put it into Encore and purchase a blue ray burner and wola its a Hd disc? “
Not if you want a menu. Go read my blog about Adobe Encore. Play only button, sure. But no menus.
We use DoStudio from NetBlender for real BluRay discs.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Patrick Morrow
June 14, 2009 at 8:56 pmSo I have no way to put chapter stops unless I run Windows on a Mac correct?
Walter Biscardi
June 14, 2009 at 8:57 pm[Patrick Morrow] “I have a Mac! “
I have 12 Macs. Encore sucks on all of them.
Walter Biscardi
June 14, 2009 at 10:05 pm[Patrick Morrow] “So I have no way to put chapter stops unless I run Windows on a Mac correct? “
You can put chapter stops in the video track of Encore, but you can’t use a Menu with BluRay authoring.
NetBlender does not recommend running DoStudio with Boot Camp on a Mac. That’s why we went with the HP Workstation. Only $1,500 including the BluRay burner.
Chris Babbitt
June 15, 2009 at 12:07 amYou can do Chapter Stops if you use Toast, and if you do the encoding in Compressor first. If you let Toast do the encoding, the chapter locations will not be accurate. Toast will do menus as well, but it seems that adding menus causes incompatibility problems with certain players.
Dennis Radeke
June 15, 2009 at 6:10 pmWalter is an excellent person on this forum and incredibly knowledgeable. His experience with Encore is documented. That being said, if you already have Production Premium CS4, I would give Encore a try before completely dismissing it.
