  • Posted by Htwhyppe on March 21, 2007 at 7:04 am
    I’ve edited my movie on Final Cut Pro HD in NTSC outside the US. It’s come time to output it to HD tape. We have rendered 10 minute pieces so that the machine will have “to think” less — the intention being to use the insert function of the HD recorder and bring it all together like that. But it won’t play. It hangs up at a different place every time. Is this a compression issue? RAM issue? Hard drive storage space issue? Suggestions?
    Htwhyppe replied 19 years, 6 months ago 3 Members · 6 Replies
  • Walter Biscardi
    March 21, 2007 at 12:26 pm
    What’s your original format?
    What’s the “rendered format?”
    What’s the storage you’re using?
    What’s the computer you’re using?
    What’s the video card you’re using?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Mark Maness
    March 21, 2007 at 1:39 pm
    Walter is correct… we need more info.
    The big issue seems to be what computer do you have? It sounds like that you may be using a G4 if your still running FCP HD. If so, the G4’s are quite up to spec for HD work and will have problems working with it, even DVCProHD has issues with the G4.
    I had similar issues with my G4 (which is now a compressor station) on a DV project that was an hour and half long. I had to break it up into 10 minute segments to write to tape. I was using FCP HD 4.5 at the time.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Htwhyppe
    March 21, 2007 at 5:03 pm
    F900 at 1920×1080 and XD Cam at 1440×1080
    24p NTSC
    Scuzy
    G5
    Black Magic
  • Htwhyppe
    March 21, 2007 at 5:21 pm
    Thanks for your input on my output. It’s a G4 (or 5, I’m really not sure — it’s a dedicated editing machine purchased about a year ago.) We experimented today and wound up bypassing Final Cut Pro and playing the rendered movie directly off the Black Magic card. This works 95% of the time. The 5% will kill us when we output unless we output and insert like crazy on the HD recorder. Is the Black Magic card calibrated fine enough to go to the exact time code frame?
    Somebody else looking at the problem is convinced we don’t have enough band width on our hard drive array. The movie is about 600 gigs. We have a terabyte of storage space.
  • Walter Biscardi
    March 21, 2007 at 6:41 pm
    [htwhyppe] “What’s the “rendered format?”
    24p NTSC”
    8bit? 10bit? DVCPro HD?
    [htwhyppe] “What’s the storage you’re using?
    Scuzy”
    What manufacturer, what unit?
    [htwhyppe] “What’s the computer you’re using?
    G5”
    G5 What?
    [htwhyppe] “What’s the video card you’re using?
    Black Magic”
    Which one?
    You’re not making this any easier. Filling out your profile with complete system information or putting your complete system information in the posts makes it easier for us to help you. Minimal information means no help on our end.
  • Htwhyppe
    March 21, 2007 at 7:38 pm
    Understood. I’ll gather this data and return with it. Thanks.
