Activity › Forums › Apple Final Cut Pro Legacy › HD Online from DVCPRO HD offline
  • HD Online from DVCPRO HD offline
    Posted by Tj Ryan on April 11, 2006 at 8:51 pm
    Offline HD Cams at DVCPRO HD codec. Ready to online the sequence. Used media manager to create a 23.98PsF 1920×1080 project. New project appears to be correct settings in browser window are accurate. Recaptured HD clips are correct. But the new clips link to the sequence play back small. Not full 16×9. Sequence settings are correct and new clips are correct. When I create a new sequence the clips play back fine. But when linked to the sequence with all of the clips it plays back small. Item properties on the off line clips in the sequence show the pixel attribute to be 1280. Why is this not giving me a true 1920×1080 sequence. Has any one seen this before when doing an On-Line using media manager.
    Gary Adcock replied 20 years, 5 months ago 2 Members · 1 Reply
  • Gary Adcock
    April 12, 2006 at 2:26 pm
    [TJ Ryan] ” Item properties on the off line clips in the sequence show the pixel attribute to be 1280. Why is this not giving me a true 1920×1080 sequence. Has any one seen this before when doing an On-Line using media manager.”
    it kept your DVCPROHD frame sizes. But hwy did you use media mangler for this step?: If the HDCAM tapes were at 24p it should have been a no brainer. (or did you offline at 29.97)
    Did you remember to change the easy setups to a non DVCPROHD Capture between versions of the project?
    Open your Offline, export an XML v2 file from your sequence(s)
    Create a new 1080 23.98 (8 or 10bit) project with a new Sequence
    Import the XML file in to the new Project and recapture the content (or connect to the uncompressed captured content) and all should be fine.
    gary
    Join us at the NAB FCPUG SUPERMEET
    Wed April 26th @ the RIO for details go to https://www.lafcpug.org/nab_2006.html
