Activity › Forums › Apple Final Cut Pro Legacy › HD on Macbook Pro 2.2 GHZ ?
  • HD on Macbook Pro 2.2 GHZ ?
    Posted by Alan Langdon on August 26, 2009 at 12:47 pm
    I am currently holding off getting a new mac, waiting another year perhaps, and am wondering if I can hold off really.
    I will be needing to edit a couple non-comercial HD documentaries (each running between 20 and 50 minutes long) on my Macbook Pro 2.2GHZ DualCore 2… I have 4 Gb of RAM and am running FCP 6.02 on Leopard 10.5.8 (can upgrade to Snow Leopard)
    I know that it is not the ideal setup, the ideal always being faster.
    But will I be able to edit them without huge memory / playback lagging? The footage is shot on Panasonic P2, I believe, so its not the lighter HDV format. I will be converting the material to Apple ProRes, I assume, using the Transfer window instead of the Capture one I am used to using.
    I have sufficient of hard drive space (1GB on external 7200 RPM FW800 drive), so I am more concerned with the RAM and processor speed. I don’t mind working in the low-res option (display), to save processor work, but I will need to transfer the footage in at high res since there is no Batch Capture feature for HD footage (in SD I often capture at Offline RT resolution then Media Manage the final cut and up-res to DV).
    Any realistic down to earth advice much appreciated!
    Joe Paolo replied 17 years, 1 month ago 4 Members · 5 Replies
  • Mark Maness
    August 26, 2009 at 2:30 pm
    Should be no problem at all…
    If I can do this sort of thing with a G5 Dual 2.7 with 4 gig of RAM. Surely, a MacBook Pro will, too. If you’re running a MacPro now, your render times will be slower but folks do this sort of work with MacBook Pros all of the time.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Joe Paolo
    August 26, 2009 at 3:25 pm
    I’m editing DVCPROHD 1080i on a G4 laptop right now. Just cutting a story line news style. But it works. G4 1.67ghz, 2 gig ram OS 10.5.8, FCP 6.0.5, G-raid3
    joe
  • David Roth weiss
    August 26, 2009 at 4:21 pm
    People have been cutting DVCProHD and ProRes for a long time on computers much less powerful that your laptop.
    If I were you, I’d just leave the material as DVCProHD, no really pressing reason you need to convert to ProRes.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Alan Langdon
    August 26, 2009 at 7:57 pm
    This is great news. A second question, regarding your sugestion: how do I Log and Transfer the footage onto the computer, coming in as DVCProHD?
    Where would I configure this? It seems like once in the log and transfer window, the only two options are Apple Pro Res and Apple Intermediate Codec. Would I configure this is the good ‘ol Audio & Video settings?
    thanks,
    alan
  • Joe Paolo
    August 27, 2009 at 3:22 am
    P2 does not transcode on import. It comes in as it was shot. DV25, DV50, or DVCPROHD.
    joe
