Activity Forums Apple Final Cut Pro Legacy HD Noobie – how to configure a Sony HDV deck with FCP 5
  • HD Noobie – how to configure a Sony HDV deck with FCP 5
    Posted by Mark Gringo on September 23, 2005 at 5:19 pm
    It looks like everything is set up ok, but i can’t get video playback in my capture and log window. Audio Video Settings says
    “Video Playback: [Missing] DVCPRO HD (1080i600 (1920 x 1080)
    Audio Playback: [Missing] DVDPRO HD Out”
    can anyone help me out here? i would be most greatful.
    “you wanna toe? I can get you a toe… I’ll get you a toe by this afternoon–with nailpolish…”
    – Walter
    Kevin Monahan replied 20 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Mark Gringo
    September 23, 2005 at 6:10 pm
    i am now trying to monitor throught the sony HDV deck and scrapping trying to monitor using FCP 5 log and capture window.
    One problem: I can log the clips fine, but when i try to “batch capture,” the deck just plays. It doesn’t record anything and it doesn’t stop at the out point.
    can someone help me out here… please!?!?
    – Walter
  • Kevin Monahan
    September 23, 2005 at 7:55 pm
    First things first. You need to use the HDV Easy Setup, not the one for DVCPro HD. Totally different format. Try that and see if that doesn’t get you going.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Walter Biscardi
    September 23, 2005 at 8:38 pm
    [MataAtlantica] “i am now trying to monitor throught the sony HDV deck and scrapping trying to monitor using FCP 5 log and capture window.”
    there’s your problem, in your first post you said you’re not seeing DVCPro HD devices, not you say you’re using HDV. Two completely different formats. use the HDV easy setups.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Mark Gringo
    September 23, 2005 at 8:46 pm
    thanks guys… oops i meant to say HDV…
    the “easy set up” option plus a tip from ken stone’s page got me up and running
    https://www.kenstone.net/fcp_homepage/review_z1u_hdv_fullmer.html
    i am editing a documentary in HDV. it is my first project in the format. it should be a learning experience 🙂
    I’ll try not to spam the board too bad.
    thanks again!
    – Walter
  • Mark Gringo
    September 23, 2005 at 9:48 pm
    one other thing…. currentlly i am using the deck to monitor audio. i haven’t found a way to monitor the HDV audio via the FCP log and capture window. Is it even possible using firewire?
    – Walter
  • Walter Biscardi
    September 24, 2005 at 2:16 pm
    [MataAtlantica] “i haven’t found a way to monitor the HDV audio via the FCP log and capture window. Is it even possible using firewire?”
    That’s because the Speaker is turned OFF by default in the Apple Capture presets. You need to go into the preset and turn the Speaker ON under the Advanced tab of the capture preset menu.
  • Kevin Monahan
    September 24, 2005 at 8:15 pm
    Walter,
    IIRC, in FCP 5 the clip settings tab has an audio preview button, so no need to change capture presets.
    Kevin Monahan
    fcpworld.com
