Activity › Forums › Blackmagic Design › HD Monitoring
  • HD Monitoring
    Posted by Cboyes on March 30, 2007 at 3:32 pm
    I recently started using the Panasonic HVX-200 and I’d like to be able to monitor my HD footage from Final Cut Pro. A colleague advised me to look into the BlackMagic Decklink HD Extreme. I don’t need the card to capture or connect to a deck, seeing as I use the P2 cards.
    For simply connecting to a HDTV monitor, is the Decklink HD Extreme the best solution?
    Also, I currently use a Sony Trinitron SD Broadcast monitor. Can I simultaneously connect to that and the HDTV monitor? I assume that would have to happen by splitting the R-Y, Y, B-Y Output. Will that cause a loss of quality or a lag in timing?
    I’d be looking to make a purchase in July ’07.
    Chris Boyes
    Kristian Lam replied 19 years, 6 months ago 3 Members · 3 Replies
  • Jimmy Brunger
    April 2, 2007 at 9:17 am
    So do you have an SD Decklink card now then, for monitoring to your sony?
    I think depending on your gfx card you may be able to monitor straight out of that to a HDMI monitor, or go for Intensity? I could be wrong..
    I too was wondering about simultanious SD/HD broadcast output using DL cards…Can you use component for SD and at the same time use one of the SDI outputs from a DL Extreme to go to your HD b/cast monitor? I’ve heard SD signals tend to look awful on HD LCDs via downsampling?
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
  • Cboyes
    April 2, 2007 at 2:27 pm
    Right now, I’m monitoring on my Sony through a DVCPro deck which is connected to my Mac through Firewire. AS far as I know, I don’t think those SDI outputs will work on just any HDTV monitor… Being wrong would be cool. Am pretty confused, emailed Blackmagic and haven’t heard anything yet…
  • Kristian Lam
    April 3, 2007 at 12:40 am
    SDI is a digital video connection and most HDTVs do not come with such support. There’s a Panasonic HDTV that has this option but it’s costly.
    The HD Extreme does not output HD and SD video simultaneously. For that you’ll need either
    a) HD Pro PCI-X
    b) Multibridge Extreme
    regards
    Kristian Lam
    Blackmagic Design
