Activity › Forums › Adobe Encore DVD › HD Menus
HD Menus
Posted by Ray Lane on January 24, 2009 at 4:15 pmHi all.
Can you do HD menus in Encore? I have been making my menus in HD, but Encore just scales them down to a widescreen SD menu. I can’t find any place to choose HD for menus.
Tom Switzer replied 15 years, 5 months ago 7 Members · 19 Replies -
Joe Bowden
January 24, 2009 at 5:24 pmWhat are the dimensions and pixel aspect ratio of the menus you have made?
Jon Geddes
January 24, 2009 at 6:50 pmYes you can create HD menus, but only for a Blu-ray Project. You must have CS3 or above for this feature.
Jon Geddes
Motion Graphics Designer
http://www.precomposed.com -
Ray Lane
January 24, 2009 at 6:53 pmI exported the movie for the background from After Effects at 1920×1080, I then tried 1280×720. Both times the only options were 4:3 or 16:9 SD. Encore just scaled the movie down.
Ray Lane
Visual Dreams -
Ray Lane
January 24, 2009 at 6:54 pmIt is a bluray project and its Encore CS4. When I bring in the movie, Encore scales it down to SD. It does still look great though 🙂
Ray Lane
Visual Dreams -
Joe Bowden
January 24, 2009 at 10:28 pmWhere does it get scaled down? In the menu? What’s the size of your menu?
Ray Lane
January 25, 2009 at 12:11 amWhen I bring in the background movie for the menu, it is 1920×1080. When I choose the movie as the background Encore scales it to widescreen SD. The only option I see is to choose 4:3 or 16:9
Ray Lane
Visual Dreams -
Heath Firestone
January 25, 2009 at 3:21 amAre you sure you have selected A Blu-Ray preset using 1920 X 1080 in Encore? If you do this, importing full resolution .psd files won’t convert to a lower resolution. I suspect you either have a DVD preset, or have your project resolution set to 720 X 480. You can check this by choosing File, Project Settings.
Hope this helps,
Heath
Ray Lane
January 25, 2009 at 5:03 amnope, all bluray. When I make the disk it’s a bluray disk with HD video….but with an SD menu
Ray Lane
Visual Dreams -
Ray Lane
January 25, 2009 at 5:14 amI am fairly convinced that Encore is just the flakiest, most poorly-written software this side of Redmond, WA.
Now when I open the project, with NOTHING having changed, Encore wants to re-encode all my assets. I even checked all the settings and they are correct. AND if I click on an asset in the bin, it says “Don’t Transcode”……Nevermind, in the middle of writing this, it locked-up. When I re-opened, it was OK again. Just goes to prove my point about it being FLAKY!! I think I want my money back 🙁
Ray Lane
Visual Dreams -
Ray Lane
January 25, 2009 at 5:19 amNow when I try to build THE SAME PROJECT THAT WORKED EARLIER, it comes back with an error!
Blu-ray Error: “device error”, Code: “3”, Note: “File can not open.(/Volumes/Video Capture/Encore/La/LaAuthorScriptHDMVSessions/_PGC_Bpgc_Ctrk_1_audio.ac3.ves)-
Ray Lane
Visual Dreams
