Activity Forums Apple Final Cut Pro Legacy HD into SD timeline issue
  • HD into SD timeline issue
    Posted by Ernie Santella on January 21, 2007 at 12:20 am
    I’ve shot and am cutting in DVCPROHD 30fps. Looks great. I tried to drop that into an Uncompressed 8-bit SD timeline to downconvert and make a DVD. When it plays, it looks bad in SD. (Like bad interlacing) I checked the settings and the timeline is set to lower field. Do you need to set field dominance to NONE? It looks better, but then will I have any other issues exporting to compressor?
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
    Kevin Reiner replied 19 years, 7 months ago 7 Members · 26 Replies
  • 26 Replies
  • Shane Ross
    January 21, 2007 at 1:48 am
    [santellavision] “I tried to drop that into an Uncompressed 8-bit SD timeline to downconvert and make a DVD”
    Why are you doing this? I export right from the DVCPRO HD timeline to Compressor and then make the DVD. The step you mention is unnecessary, and might be adding the interlacing you are seeing.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Walter Biscardi
    January 21, 2007 at 2:09 am
    [santellavision] “I’ve shot and am cutting in DVCPROHD 30fps. Looks great. I tried to drop that into an Uncompressed 8-bit SD timeline to downconvert and make a DVD.”
    As Shane notes, this step is completely unnecessary, just send your DVCPro HD timeline to Compressor and go.
    But did you shoot 720 or 1080i? If you shot 1080i, that’s Upper Field First native so when you dropped it into the 8bit SD timeline, you reversed the fields and it will look very ugly.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Ernie Santella
    January 21, 2007 at 2:27 am
    Shot 720P30. I was also trying to lay to BetaSp using AJA Io (No Kona yet) So, I can’t do down convert thru Kona at this time. What’s the procedure to drop the 720P timeline into a Uncomp8?
    Ernie Santella
  • Walter Biscardi
    January 21, 2007 at 2:39 am
    [santellavision] “What’s the procedure to drop the 720P timeline into a Uncomp8?”
    Have never had to do this, but my guess would be you might have to move your footage one pixel up or down vertically to get rid of your interlacing issue. Also ensure that the distortion is not causing any issues.
  • Jeremy Garchow
    January 21, 2007 at 2:43 am
    I’d also turn off the field rendering on the timeline to keep it progressive. Another way to do this is to export a reference movie in full resolution and then use compressor to do an advanced format version to Uncompressed 8bit NTSC.
    Jeremy
  • Ernie Santella
    January 21, 2007 at 3:28 am
    Moving it a line didn’t help. Turning off the fields as mentioned before does work and it looks good. But what Edit to tape, any issues with laying to Beta with the fields set to off?
    Thanks you guys for your help. I just bought my HDX900 HD camera and this is my first HD project. My next purchase is the KONA 3 card.
    Ernie Santella
  • Walter Biscardi
    January 21, 2007 at 3:31 am
    [santellavision] “Moving it a line didn’t help. Turning off the fields as mentioned before does work and it looks good. But what Edit to tape, any issues with laying to Beta with the fields set to off?”
    You’ll just have to try it and see what happens. I always use my Kona 3 to do the downconvert from 720p to SD in realtime and whatever the card does, it looks great.
  • Ernie Santella
    January 21, 2007 at 4:15 am
    One last question. I think I’ll just get the KONA 3 and make this easy. Is it working OK on a 2.66 MacPro? And what do you guys use for ‘Ref In’ to it? I’ve been searching posts and can’t find that.
    Ernie Santella
  • Walter Biscardi
    January 21, 2007 at 4:17 am
    been running quite a while now on our Mac Pro Quad 3.0. I have a Horita BSG-50 black burst generator for ref.
  • Ernie Santella
    January 21, 2007 at 4:25 am
    OK, So, my old analog NTSC burst gen will work, that’s great. You guys all got me convinced the Kona3 is the way to go.
    Walter, did I read somewhere that you can keep and use a AJA IoLA for analog vid/aud outputs for dubbing?
    Ernie Santella
Page 1 of 3
