Activity Forums Avid Media Composer HD in SD Project
  • HD in SD Project
    Posted by Chris Magid on March 2, 2006 at 5:24 pm
    Question 1:
    Will a Panasonic 1200a VTR output a anamorphically squeezed downcovert of HD footage? Meaning we want to take some HD100 1080/59.94i footage and use it in SD 16×9 project. The manual mentions a HV squeeze but was unsure of it’s application.
    Question 2:
    Is 1080/59.94i the right choice for easy mixing with SD NTSC interlaced content? As far as the downcovert goes, I suspect it is fine. But we may also way to get the full resolution HD into After Effects projects to combine with SD elements for SD anamoprhic 16×9 output. Once again DVCPro HD Doable?
    I thought about 720p but was concerned with adding pulldown to the 24P variation or other conversion of the 60p to interlace via software like After Effects. Any enlightenment here?
    Chris Magid
    RTVF
    chris@gortvf.com
    Chris Magid replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
