Activity Forums Adobe After Effects HD in After Effects
  • HD in After Effects
    Posted by Austen Collins on June 15, 2007 at 2:38 am
    I’m editing my first HD project. It was shot on the new Panasonic and I imported the files into FCP from the P2 cards. All of the cuts are layed out now I want to do some basic motion graphics in AE 7.
    How should I export the footage to use in After Effects 7?
    How do I export the footage from AE7 and bring it back into FCP?
    The format is DVCPROHD 1080i60 1280×1080 29.97 fps
    I’m scared of quality loss during all of this exporting. If this has been answered already i would be grateful if you could direct me. Thank you.
    Austen Collins replied 19 years, 3 months ago 2 Members · 2 Replies
  • Kevin Camp
    June 15, 2007 at 3:55 pm
    to avoid quality loss, you generally would like to export clips that will be effected in ae to a lossess or uncompressed format. most people choose the lossless animation codec, but tiff, targa and png sequences will work well too.
    however, your hd clips will be huge… if you don’t have the disk space, you can pull clips (or copies of the clips) directly from the capture/scratch folder that fcp put the transcoded mov files in when it converted them from the p2 (mxf) files at import. or look into getting a reference movie out of fcp for the clips you need. fyi, ae will work better (by better, i mean quicker and easier) with the lossless codec or an image sequence than with dvcprohd due to intraframe/temporal compression, but it will work with dvcprohd.
    if you’re ae work will be ‘basic motion graphics,’ you may be best off to produce the graphics in ae, render as lossless with alpha (choose straight-unmatted in the output module settings) and then composite those in fcp. that way you’ll avoid any further loss in the dvcprohd footage (remember even if you render lossless out of ae, fcp will still convert to dvcprohd at import, so any original footage will be compressed again). you can use footage for placement, just remove/hide it before render. if you have to render fully composited clips, still render to the lossless codec, or an uncompressed image sequence.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Austen Collins
    June 15, 2007 at 4:28 pm
    ahhh thank you so much. These are the only motion graphics I have
    https://www.austencollins.com/video/comm1v1.mov and I think they will be easy to composite over the FCP video. Thank you for taking the time to help me out.
