Activity › Forums › Adobe Premiere Pro › Hd import Settings
Hd import Settings
Posted by Doug Tepe on October 5, 2008 at 7:53 pmI have shot some footage (720 30pn) on a Panasonic HVX200 with a P2 card.
I have tried several settings when creating a new project in Premiere Pro CS3 and every time I try to capture my record button is grayed out.
Can you help me with my settings in the Premiere Project.
Hail the Cow.Jacquelyn Pillows replied 16 years, 11 months ago 4 Members · 6 Replies -
Vince Becquiot
October 5, 2008 at 11:53 pmWhy are you trying to capture ?
You need to drag the content folder from the P2 card to your local drive, then import everything from the video subfolder to premiere pro.
Vince Becquiot
Director | EditorKaptis Studios
San Francisco – Bay Area -
Doug Tepe
October 6, 2008 at 3:56 amThanks for the quick response…I thought that I should be able to drag the files to my Mac drive but the P2/Camera is not showing up when I plug it in. Is there some software that would make that possible? I am still confused about what my settings should be when I create a new project in Premiere Pro.
Hail the Cow
Doug -
Vince Becquiot
October 6, 2008 at 4:10 amYou need to hit the playback button on the back of the camera once (takes you to thumbnail mode), then hold it again for a few seconds. That will take the camera to transfer mode. I believe on a Mac, you would be using Firewire (unlike USB only on a PC)
Make sure that your camera transfer menu setting (9?) is set to Firewire as well.
Vince Becquiot
Doug Tepe
October 7, 2008 at 3:40 amThanks for the advice on the camera/p2 card.
Can you give me some advice about the Premiere Project settings for 720 30pn?
Hail the Cow
Doug -
Vince Becquiot
October 7, 2008 at 3:49 amSelect the DVCPro HD, 720 24p preset, then go to the custom settings and change the frame rate to 30p. That’s about it.
Vince Becquiot
Jacquelyn Pillows
October 6, 2009 at 12:35 amI’m actually having the same problem. I’m shooting in 720 24p/n but whenever I attempt the transfer Adobe says ” File format no supported. What the heck am I doing wrong, I’ve tried everything. Please help!!
Jax
