Activity Forums DSLR Video HD H2.64 to SD conversion
  • HD H2.64 to SD conversion
    Posted by Nishi Sharma on March 14, 2011 at 10:43 am
    I have not been able to convert HD to SD satisfactorily to edit in FCP. I use MPG Streamclip with the following settings:
    Compression: Apple DV PAL
    Quality: 100%
    Frame Size : 720×576 (DV PAL)
    Interlaced scaling: On
    The problem is slight strobing when the subject moves in the frame, which is very disconcerting. If I turn the Interlaced scaling off then I can’t view the movie on an SD monitor.
    I would greatly appreciate help as it is driving me mad.
    I have not problems when I am working in HD and the results are great.
    Pete Burger replied 15 years, 6 months ago 3 Members · 3 Replies
  • Jason Jenkins
    March 14, 2011 at 8:04 pm
    Why don’t you edit in HD, then downconvert for delivery if necessary.
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
  • Nishi Sharma
    March 14, 2011 at 8:32 pm
    Yes, I have done it that way in the past but then Compressor takes a long time to prepare the files for DVD SP, especially for a 45 min programme.
    Where as if I convert it to DV PAL frmat first then a 45 min long programme takes only 15-20 min to prepare files for the DVD SP. So, that seemd sensible.
  • Pete Burger
    March 15, 2011 at 9:16 am
    [Nick 2746] “If I turn the Interlaced scaling off then I can’t view the movie on an SD monitor.”
    I’m not sure, if I understand correctly. If you turn interlaced scaling to off, results in a file that can’t be played? Or is the quality not good?
    You could try to resize and convert to a different codec, like Photo-Jpeg at 90% (or higher), which produces quite good results.
